The Best Of Both Worlds (383 Build)
#2045590
04/03/16 06:14 PM
04/03/16 06:14 PM
Posts: 179 South of Seattle
MBigDaddyM
South of Seattle
I have a 1967 D100 CSS 383/Auto, I consider it a rare truck as aside from being a big block CSS it has the individual gauges and power assist steering, among other items. The 383 which I believe to be original has a collapsed lifter and the crank looks like it will need to be machined or replaced. What I would like to do is rebuild the 383 to 69-70HP specs internally, but externally I would like to use all the 1967 performance parts so it looks like it could have come from the factory that way.
This is what I believe I need so far. Cam 68-70 440 268°/284° P4452783 Exhaust Manifolds 67 440 Right 2806900/Left 2806974 Heads 67 440 2780915 Intake 67 383 2205968 Carb 67 383 Carter AFB 4299 96251
My questions are these 1. Are my parts/numbers above the correct performance parts? 2. What is a good engine rebuild kit to stay within these parameters? 3. According to my research there was an unsilenced air cleaner used on the 67 HP models that was similar to what was used on the 68-70 HP models. Does anyone have a part number for the 67? 4. I have looked at the Edelbrock DP4B intake, but is this something that could have been ordered either from the factory or from Direct Connection in 1967?
Thank you for your help. -BD
Will the last one leaving the US please turn out the lights.
Re: The Best Of Both Worlds (383 Build)
[Re: MBigDaddyM]
#2046331
04/04/16 03:50 PM
04/04/16 03:50 PM
Posts: 31,200 Oregon
AndyF
You might want to post this in the resto area or the truck area. Most guys in the race section don't pay much attention to factory correct part numbers.
If it was my truck I'd use a 440 crankshaft to turn the 383 into a 426 and then use all correct external parts.
[Re: MBigDaddyM]
#2046372
04/04/16 04:29 PM
04/04/16 04:29 PM
Posts: 5,173 CT
GTX MATT
CT
915 heads were 440 only, all 383s came with the 516 heads.
[Re: MBigDaddyM]
#2046464
04/04/16 06:39 PM
04/04/16 06:39 PM
Posts: 4,219 New York
polyspheric
New York
Not sure why you expect someone like Govier or Ehrenberg to be looking under your hood? You're going to a lot of trouble to do things that are not cost-effective.
Boffin Emeritus
[Re: MBigDaddyM]
#2046483
04/04/16 06:58 PM
04/04/16 06:58 PM
Posts: 972 Chicago
PurpleBeeper
Chicago
I would suggest the following:
1. Use your stock heads, but put the larger exhaust valves in it. You can upgrade both intake & exhaust valves if you want, but for your use, I'd recommend just the exhaust to stock '68+ size.
2. Run your existing carb/intake if it's a 4-barrel. If you have a 2-barrel 383, find a stock intake and carb.
3. No need to change your exhaust manifolds
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: MBigDaddyM]
#2046517
04/04/16 07:21 PM
04/04/16 07:21 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
You were a little quick with that. The DP4B had a part number on it to make it NHRA legal but I don't think that happened till after 67. The stock iron intake isn't that great, especially the narrow pattern 67 with an AFB, doctor up a Performer RPM .
Mainstream Media is the new Pravda
[Re: MBigDaddyM]
#2047663
04/06/16 03:12 AM
04/06/16 03:12 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
I'd take that original engine, lifter crank and all, and shove it in a corner. Go dig up a 400 and dress it up like a 383 how ever you like, even stroke it with a 3.75 crank and enjoy the truck. I wouldn't put a nickel in a numbers engine but if it makes you feel better afterwords correct the crank and a set of lifters. And have it ready to run. Years ago I had a brilliant idea to freshen a numbers engine, the machine shop had a mishap and gouged the block requiring a sleeve. Never again... Hand the next owner the engine and smile
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: MBigDaddyM]
#2048096
04/06/16 04:42 PM
04/06/16 04:42 PM
polyspheric
New York
A certain person swapped a 340 into an early (narrow) A body, complete with the big passenger-side exhaust manifold, big intake manifold, and fairly hot cam (kept the driver-side 273 manifold ported to paper-thin) with almost complete success for many years: "It's the stock 273".
You're building a defense against a question that may never be asked ("Is it stock?").
Boffin Emeritus
