Crate HEMI Head Flow ? #2045399
04/03/16 03:00 PM
04/03/16 03:00 PM
British Columbia Canada
Challenger340 Offline OP
What are you guys seeing for Flow out of the Mopar(edelbrock ?) Crate Engine HEMI Heads ?
I'm pretty familiar with the Stage V and others... but strangely just never played with these ?
Better to be a "has been" than a "never was".
Re: Crate HEMI Head Flow ? [Re: Challenger340] #2045403
04/03/16 03:02 PM
04/03/16 03:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Edelbrock heads or old mp heads?
Re: Crate HEMI Head Flow ? [Re: Challenger340] #2045412
04/03/16 03:12 PM
04/03/16 03:12 PM
Good question, I dunno ?
They have the Mopar part #2531110-M on them ? seems to me if I recall they were Eddy maybe for Mopar ? But again, like I said, I just never played with them before, so NO idea ?
Re: Crate HEMI Head Flow ? [Re: Challenger340] #2045457
04/03/16 03:55 PM
04/03/16 03:55 PM
So. Burlington, Vt.
So. Burlington, Vt.
I haven't had one of those here in a while, but as I recall the edelbrock made version has the "E" inside a circle for a foundry mark on them, but I wouldn't swear to that.
To look at them in person, it's easy for me to tell them apart from the earlier version.
Looking through some notes, tested on a 4.250 bore without a notch for the intake valve, and piece of 7/16x14 bolt threaded into the head bolt hole so it's basically flush with the floor, the early heads flow 3-teens, and the edelbrock version mid-320's.
A bigger bore, or a bore notch for the valve is worth a few cfm.
What I would consider a "normal" port job, no holes, no dimples, no tubes, they flow 375-380.
If you make them "bigger", they seem to flow more, but that usually seems to require some tubes.
The new Victor heads flow just over 400 ootb......and they have tubes in them already.
Re: Crate HEMI Head Flow ? [Re: Challenger340] #2045720
04/03/16 10:00 PM
04/03/16 10:00 PM
Thanks so much Dwayne
Marty texted me Friday and said 3-teens as dis-assembled from running, so I will have to look better tomorrow(monday) and see what's going on ? or any room for improvement.
It's just a street/pump gas "hydraulic" flat tappet deal, so I dunno if he even needs much more ?
Thanks again.
Re: Crate HEMI Head Flow ? [Re: fast68plymouth] #2047210
04/05/16 04:24 PM
04/05/16 04:24 PM
an8sec70cuda Offline
iagree There will be a small (1/2" or so) diameter circle w/ an "E" in it...Edelbrock's font for the letter. That's the Edelbrock casting MP heads. It's under the valve cover near the exhaust side if I'm not mistaken. I have a set sitting on the workbench at home.
CHIP
'06 GMC 2500HD LBZ Duramax
