Re: Carbon canistor
[Re: Dons Dart]
#2045400
04/03/16 03:01 PM
04/03/16 03:01 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you are "restoring" a car you should have the factory service manual as part of your reference material, the info you seek is in that. I don't have the info you seek though google might.
Re: Carbon canistor
[Re: Supercuda]
#2045484
04/03/16 04:08 PM
04/03/16 04:08 PM
Posts: 440 Canada
Dons Dart
Canada
If you are "restoring" a car you should have the factory service manual as part of your reference material, the info you seek is in that. I don't have the info you seek though google might. I have tryed but no luck.everthing so far has been a no brainer till this, i have all the hoses but dont know were to go to.
Re: Carbon canistor
[Re: Dons Dart]
#2045863
04/04/16 12:25 AM
04/04/16 12:25 AM
Posts: 1,822 Colorado
denfireguy
Colorado
The three lines on the canister connect to the tank vapor separator, the fuel bowl vent and the carb. If the carb has been replaced, it likely does not have the fuel bowl vent anymore. The top of the canister has the connections labeled. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: Carbon canistor
[Re: Dons Dart]
#2046072
04/04/16 09:39 AM
04/04/16 09:39 AM
Posts: 7,664 IN
ahy
IN
How do i post pics of what i have,you have been great so far. I use Photobucket. Put the picture in the bucket and view it. At the bottom right there should be a panel with options on doing something with the pic. The bottom option is "copy image" or something like that. Click or hover over the copy image box until it says "image copied". Then past in your post.
