904 Trans Cases #2045224
04/03/16 12:43 PM
04/03/16 12:43 PM
Muncie
Racebuddy Offline OP
Muncie
Who makes a super case for 904???
anyone have one running now??
I am running the carbon fiber shield under my B body, not much room to spare. I gotta do away with the shield
Re: 904 Trans Cases [Re: Racebuddy] #2045231
04/03/16 12:58 PM
04/03/16 12:58 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Never heard of one. 904 in a b-body should have more room then my a-body.
Re: 904 Trans Cases [Re: rickraw] #2045468
04/03/16 04:01 PM
04/03/16 04:01 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
There is no supercase 904 or 727. Reid makes superglide and turboglide case which are gm based transmissions.
However, A-1 makes an adapter that allows cutting off the thin bellhousing at the pump and bolting their part to the pump. This allows you to bolt any Reid pattern bell which are blow proof.
Reid, BTE, and QuickTime all offer bells using this pattern.
I offer the bells and adapter ring for this application.which is popular with the R5 nascar engines.
