Re: Carter AVS or Holley?
[Re: ChuckinNY]
#2044744
04/02/16 09:37 PM
04/02/16 09:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: ChuckinNY]
#2044911
04/03/16 12:08 AM
04/03/16 12:08 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
three things that take no imagination
SBC
Holley Carb
Ford 9"
look at any generic street rod.
[Re: ChuckinNY]
#2044987
04/03/16 01:40 AM
04/03/16 01:40 AM
RapidRobert
All (OE '68-'71) AVS's are lean from Ma trying to meet the discombobulated Federal emission standards of the day (Furd/Chebby too). convert it to use Eddy Performer 2 step metering rods/jets. Fill the domed metering rod caps with JBweld then cover it with scotch tape then turn it over & let it set for 2 days so the mud will settle & harden out level then pull the scotch tape. Start with a rod/jet combo several tho larger (richer) than (AVS) stock on the power/cruise steps & go from there. Purchase a strip kit with rods/jets close to the dia's your AVS has
[Re: ChuckinNY]
#2045003
04/03/16 02:13 AM
04/03/16 02:13 AM
Posts: 10,201 Someplace you aren't
SomeCarGuy
The avs will be fine. The holley will be fine. Which do you feel most comfortable working on? Sounds like the car is mostly stockish so the avs woukd look more "correct" and you likely have the oem fuel line already.
I want my fair share
[Re: ScottSmith_Harms]
#2045004
04/03/16 02:16 AM
04/03/16 02:16 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I agree, nothing wrong with the stock AVS at all. Without a doubt... Leave the 'MP' fer someone else...
[Re: ChuckinNY]
#2045147
04/03/16 10:28 AM
04/03/16 10:28 AM
Posts: 4,766 Holland MI Ottawa
2boltmain
Holland MI Ottawa
If you are not set on 100% stock and have a little $ to spend why not try the Street Demon carb? Youd have a brand new carb and its intended target is high perf street driven vehicles.
Keep old mopars alive.
[Re: ChuckinNY]
#2045175
04/03/16 11:25 AM
04/03/16 11:25 AM
Posts: 3,916 usa
lewtot184
usa
Its a 69 GTX...440 auto with ac.Mostly original.It had a repaint many years ago and its a nice driver. I have a feeling I cant go wrong with which ever carb I go with! look at the front of the carb and see if the numbers 4640s are stamped on it. i have a '69 r/t 440 auto with it's original 4618s avs. what i've done is change out the leather accelerator pump plunger for newer viton edelbrock. i use the stock .101 tall primary jets with a 16-575 metering rod (.065/.060/.052 three step. these are no longer available but an edelbrock .065/.052 will work). stock .095 jets in the back will work with a stock engine. i've unplugged the mixture screws at the base of the carb and they're backed out 3 1/2 turns. the only "tricky" part is the idle jet. it's the small brass tube that hangs out the bottom of the primary cluster. these are .031" from the factory, too small. i've tried several sizes from .031" to .040". i've settled on .033" which is a tad lean (manual transmission carbs used .035" which is about right). i use a .028" afb squirter i modified to fit the avs (simple to do) and have the pump shot rod in the top hole. this carb starts, drives and performs quit well with the near stock engine (summit 6401 cam; idles smooth, very good low end). keeping the avs lets retain all the stock linkage and choke assembly and you give absolutely nothing up in performance to a comparable holley.
[Re: ChuckinNY]
#2047533
04/05/16 11:39 PM
04/05/16 11:39 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
it is a 4640s. I still have the metal tag that mounts on the base of the carb with 4640s stamped on it. Chuck, I'd say rebuild the AVS and start there. If you don't like it, try the Carter. I switched my 1967 2bbl 383 Satellite over to an AVS 8 years ago, never regretted it for a moment. I'm not a performance guru, but like to have some power. Easy to rebuild, easy to drive, no fuss no muss. You've got the tag, so for a kit just call Larry Isgro Carburetors, he is on Long Island unless he retired, but I've been getting my rebuild kits from him since 2001. http://www.yelp.com/biz/larry-isgro-carburetors-wantaghBest, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: Supercuda]
#2047551
04/05/16 11:58 PM
04/05/16 11:58 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
SBC
Holley Carb
Ford 9"
look at any generic street rod. LOL The Holley 4150 is an engine fire waiting to happen If you have the Carter 4640S use it
[Re: ChuckinNY]
#2048364
04/06/16 10:21 PM
04/06/16 10:21 PM
67SATisfaction
Albany, NY
Art,thanks for the info and the link for the rebuild kits. On a side note,how do you like those Alfas? I was looking at a local Alfa Spider Veloce for sale..looks like a nice clean car that needs a little TLC! Something different from the Mopars,but I,m open to anything on wheels that is fun to drive. I do love them. Yes for sure Alfa's are super fun to drive, manual shift and to get the power out you rev high, so the experience is just great. Handling and balance are excellent. Parts and advice are plentiful (surf around, look in their classifieds and even ask if anyone knows about your Spider on www.alfabb.com) and not expensive. Upgrades are also plentiful. They do take extra care though, like things have to be repaired before they fail.. - My '82 has the fantastic V6 and been very reliable. - The '94 has the bigger V6 with 24valves, but has electrical issues that are hard to really get completely sorted out. Modern stuff gets complicated. Bummer. But don't let a '94 sedan scare you away from a nice used Spider! They would be a great start, Good luck! - Art
[Re: ChuckinNY]
#2049067
04/07/16 06:35 PM
04/07/16 06:35 PM
Posts: 14 New York
ChuckinNY
New York
Thanks for all the help and advice! I have a feeling that I should be good with either carb. I think what I,ll do is,when its ready to fire up,I,ll put the Carter back on and use that until the car is up and running and all the bugs are worked out. Then as time permits,I,ll try the Holley and see if there is much of a change. I,m not looking for the last 10th of a second or anything like that,but since I have the Holley and probably will keep it,I might as well monkey around with it. Back in the day when I was constantly buying and selling Cudas and Roadrunners and all the other Mopars,it was just normal to pull the original carb and put a Holley on. The GTX is the only one I can recall that I kept the original carb on! It has served me well.
[Re: Paul_Fancsali]
#2049578
04/08/16 11:36 AM
04/08/16 11:36 AM
Posts: 792 Earth
Rob C
Earth
Other then the carters loving to cut out in sharp bends unless you really work them a carter AVS is fine . If such is the case, your float levelis low. Raise it up and it won't cut out. I vote AVS. OE 750 or Edel. 800.
[Re: Runner]
#2049851
04/08/16 05:06 PM
04/08/16 05:06 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
i think either carb is fine, but im always surprised at how much flack holleys get for leaking. i have holleys on all my junk and none of them leak. they all run good and are trouble free. now, i have worked on some that had issues when no fuel filter was used and there was a bunch of junk in the tank Same here. I have had the same 750 Holley DP on my sons Dart since 1997 and it has never leaked and works flawless. The 850 on my 63 has been on it since 2006 and is the same with never a leak and works great. Carters and Eddy carbs are good too as I have no problem using either. I just like Holley's better on my muscle cars. Ron
[Re: Rob C]
#2050093
04/09/16 12:18 AM
04/09/16 12:18 AM
Posts: 279 pgh pa
captaindodge
pgh pa
Other then the carters loving to cut out in sharp bends unless you really work them a carter AVS is fine . If such is the case, your float levelis low. Raise it up and it won't cut out. I vote AVS. OE 750 or Edel. 800. Trouble is when you raise up the float level it will cut out under hard braking!
