Re: Will these tires fit a 68 roadrunner?
[Re: Kern Dog]
#2045696
04/03/16 09:39 PM
04/03/16 09:39 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
My 70 Charger has an 18x9 front with a 275-40-18 tire. The rear is an 18x10 with a 295-45-18. Plenty of clearance and I have my car a bit lower than stock height. Don't go by this as a gauge as to what will fit a 68 Plymouth B body rear , the charger has a huge rear wheel well compared to the Plymout. Front , I'm not sure if the fronts have more room on the Charger ???
[Re: Gerald l]
#2046090
04/04/16 10:26 AM
04/04/16 10:26 AM
Posts: 57 GA
Gerald l
GA
I've seen some people run a225/50r17 or a 245/45r17 in the front of a 68 roadrunner with a 8 inch wide wheel. On my rears I have plenty of space to go a little bigger and wider. I have a 18x9 on the rear with a 245/45. I just want a little more side wall on both.
[Re: Kern Dog]
#2046096
04/04/16 10:34 AM
04/04/16 10:34 AM
JohnRR
U.S.S.A.
Are the inner and outer wheel houses the same in all the 68-70 b body cars? No they are not. Dodges have more room in the rear than Plymouths.
[Re: Gerald l]
#2046327
04/04/16 03:44 PM
04/04/16 03:44 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I've got 295/55-15 tires on the rear of my '68. They fit, but just barely.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: JohnRR]
#2046637
04/04/16 09:51 PM
04/04/16 09:51 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Are the inner and outer wheel houses the same in all the 68-70 b body cars? No they are not. Dodges have more room in the rear than Plymouths. Thank you. I'm glad to learn this.
