Headlight relays #2043891
04/01/16 09:24 PM
04/01/16 09:24 PM
70duster340 Offline OP
Let's see some pics of the various setups. Trying to get an idea of how to set mine up.
Thanks!
Re: Headlight relays [Re: 70duster340] #2043896
04/01/16 09:33 PM
04/01/16 09:33 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
There is someone that builds them , you cant make them at the quality he does for the cost.
http://www.forbbodiesonly.com/moparforum/showthread.php?88359-Plug-and-play-headlight-relay-kits
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Headlight relays [Re: 70duster340] #2043909
04/01/16 09:49 PM
04/01/16 09:49 PM
CA
crackedback Offline
crackedback  Offline
CA
Thanks for the compliment astjp2 smile
Re: Headlight relays [Re: astjp2] #2044112
04/02/16 01:24 AM
04/02/16 01:24 AM
Victoria B. C Canada
gold66cuda Offline
gold66cuda  Offline
I second that, great quality and a great upgrade.
Re: Headlight relays [Re: 70duster340] #2044409
04/02/16 01:08 PM
04/02/16 01:08 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
I can vouch for Rob (crackedback) as well. Very well put together relay kit he makes. It was one of the best upgrades I've made to my Dart.
Re: Headlight relays [Re: 70duster340] #2046584
04/04/16 08:38 PM
04/04/16 08:38 PM
Thanks folks, but I have already purchased the parts needed. I was just hoping that I could get some ideas about how to mount the harness, additional parts, etc.
Re: Headlight relays [Re: 70duster340] #2046608
04/04/16 09:15 PM
04/04/16 09:15 PM
CA
crackedback Offline
crackedback  Offline
CA
Pick a spot and wire it up.
I've built kits to mount them all over the engine compartment. I like them in the compartment if you ever drive in wet weather unless you buy a weatherproof mount/box.
Re: Headlight relays [Re: 70duster340] #2046770
04/05/16 12:36 AM
04/05/16 12:36 AM
BDW Offline
BDW  Offline
Re: Headlight relays [Re: 70duster340] #2046877
04/05/16 04:02 AM
04/05/16 04:02 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
These cheap relays seem to work fine, and can be snaped together.
Link:
http://www.amazon.com/dp/B017VDI0GY?psc=1
Right now I have 4 or 5 of these snapped together and mounted with one bolt. Wiring looks a bit ratty. I will replace the relays and individual fuses with a combination fuse/relay block (bussman or blue sea?) when I get around to making the car look good.
Re: Headlight relays [Re: 70duster340] #2047060
04/05/16 01:27 PM
04/05/16 01:27 PM
CA
crackedback Offline
crackedback  Offline
CA
There are better designed relays to use, especially for headlights, than the cheap ones referenced.
Pick your parts, pay your money.
Re: Headlight relays [Re: 70duster340] #2047313
04/05/16 07:23 PM
04/05/16 07:23 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
- Stu Harmon
Re: Headlight relays [Re: 70duster340] #2047930
04/06/16 01:43 PM
04/06/16 01:43 PM
Where can the relay blocks be found?
Re: Headlight relays [Re: 70duster340] #2047940
04/06/16 01:54 PM
04/06/16 01:54 PM
Seattle, wa
tanis4457 Offline
tanis4457  Offline
Seattle, wa
Get some SPDT Bosch/Tyco relays, they are good quality and should last a long time.
https://www.waytekwire.com/item/75411/?g...axpVxoCPOjw_wcB
Re: Headlight relays [Re: 70duster340] #2047971
04/06/16 02:31 PM
04/06/16 02:31 PM
None
71rm23 Offline
71rm23  Offline
None
Contact "crackedback" member here
Re: Headlight relays [Re: 71rm23] #2047980
04/06/16 02:42 PM
04/06/16 02:42 PM
CA
crackedback Offline
crackedback  Offline
CA
Thanks, but, it's not worth the effort to sell a couple of relay blocks, along with time to ship them out, unless someone was buying 20+.
Contact waytek, Del City or a local electrical house for them.
I will say, buy ONLY Bosch/Tyco relays. Failure rates are MUCH lower than the cheap units.
Re: Headlight relays [Re: 70duster340] #2048125
04/06/16 05:20 PM
04/06/16 05:20 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Anything electrical you want (including factory style plugs).
http://www.mouser.com/
- Stu Harmon
Re: Headlight relays [Re: feets] #2048232
04/06/16 07:40 PM
04/06/16 07:40 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Not much help for those that have already bought there stuff. But for a little different flavor of options out there, I went with these weather tight ones. Very small, Mini or Micro (I forget) relay's, and an even smaller circuit breaker with one spare breaker inside of each bright or dim circuit box. The relay is about 1/2" square by ~1-1&1/8" tall. I've put 6 months on them with no failures yet.
Easily accessed, and mostly out of sight, but not entirely. I think they're mostly used by motorcycle guy's for their size and weather seal.
I've presently misplaced the prints & info on them that I would 've liked to have shown here.
Re: Headlight relays [Re: 70duster340] #2048279
04/06/16 08:31 PM
04/06/16 08:31 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
http://terminalsupplyco.com/Store/Product.aspx?pc=TYR-005-1240
I use the SPST relays. You get two output terminals so each bulb gets it's own direct power feed( twin terminals 87 normally open). No need to splice the lines. I used one for the low beam and two for the hi beams in my 4 lamp system. About $14 per relay IIRC. Terminal Supply has the connectors and terminals also. They have a $20 minimum order policy so get the order right before you finalize.
Re: Headlight relays [Re: 70duster340] #2048337
04/06/16 09:40 PM
04/06/16 09:40 PM
Thehemikid, I like your setup. Neat and professional looking.
Re: Headlight relays [Re: Pynzo] #2048588
04/07/16 03:07 AM
04/07/16 03:07 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Same relays are under $7 each through Waytek.
Waytek Wire has a very good selection and good prices on most stuff, but has a $5 line minimum on most items.
Del City has a good selection and decent prices, and most items do not have a line item minimum.
Terminal Supply has a good selection, but are pricey. You also usually need to get a price quote from them, as I don't remember them listing prices online.
I buy about $800-1000 a year in wiring supplies, either for personal use or for a local shop. About 80% comes from Waytek, 15% from Del City, and the remaining from Term Supply if I forget to order from the other two and need that day (they are 30 min away).
Free advice and worth every penny...
Factory trained Slinky rewinder.........
