growls like it's on mudders #204313
01/25/09 07:05 PM
01/25/09 07:05 PM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
My 2004 RAM 2500 4x4 all at once started growling like it's on super mudder tires. It does it over 45 mph or so and continues even if I slip the trans to nuetral. 1st started only on deceleration, like from highway speed to stop sign. Is it rear gears? It is limited-slip. I do pull a small open car trailer with a A body several times each year and truck has 94,000 miles on it now.
Thanks for your thoughs, fix ideas welcome also.
4bbl If you can't hear it coming what's the point.......
Re: growls like it's on mudders [Re: 4bbl] #204314
01/25/09 07:24 PM
01/25/09 07:24 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
the late model limited slip 9 1/4s have had problems with the the clips that hold the clutch pack together and can work loose causing damage to the rear. Have it checked.
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: growls like it's on mudders [Re: 4bbl] #204315
01/25/09 08:18 PM
01/25/09 08:18 PM
u joint maybe
