Re: New Stroker Combo Going Together - Thoughts?
[Re: JACK1440]
#2042884
03/31/16 06:48 PM
03/31/16 06:48 PM
Posts: 20,189 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Screw it together and go have FUN as it will run great. Without knowing exactly how fast you want to go I did about the same thing. When I built my Keith Black 572 the cam was spected for my B1 heads but My Indy 440-1 heads were ready sitting on the shelf so I threw them on. At that time they were flowing under 350cfm and although my Daytona was light (2300 pounds) it still went 8.40@160mph with a bad brand new BG400 fuel pump on it. Cam was in the 800 plus lift area, Indy intake, 1050 carb.
[Re: JACK1440]
#2043335
04/01/16 08:42 AM
04/01/16 08:42 AM
Posts: 20,189 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I went with 1.7 rockers on the B1's and I think 1.65's on the 440-1 heads. The only other thing you may want to consider is if and when you want to step up to a different head are the pistons valve reliefs going to be OK. My pistons were Wiseco Pistons made for 440-1 heads so I had Tom Hemphill go ahead and cut them for my B1 heads so the engine was balanced and ready for the switch-over.
[Re: JACK1440]
#2043474
04/01/16 01:24 PM
04/01/16 01:24 PM
Posts: 31,052 Oregon
AndyF
Thanks guys, I'm starting to feel better about this. My current springs bind at .75. Sounds like I may need to go to a spring that allows more lift. I also run 1.5 rockers might need 1.6. Well you aren't going to make a ton of power with 1.50 rocker arms. You have to run a 0.500 lobe lift cam to get .750 valve lift and that is just about the end of the line for a stock Mopar setup. At 0.500 lobe lift you start to run into problems with the oil gallery unless you have bushed lifter bores. On my EZ heads I run 1.85 Jesel rocker arms and .890 lift. But it takes a serious investment in time and money to make that happen. It is easier to switch heads than to put that much work into a set of EZ heads.
[Re: JACK1440]
#2043516
04/01/16 02:09 PM
04/01/16 02:09 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Thanks Andy. I'm seriously thinking going to a 1.6 - 1.7 rocker to get in the .800 lift range and live with the heads for a while. I do have bushed lifter bores. My engine builder prefers the higher ratio rockers. You buying rockers anyway......put some ratio on it. Go 1.8s
[Re: JACK1440]
#2044082
04/02/16 12:47 AM
04/02/16 12:47 AM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
You're gonna need around 800hp for those 9.30's. 345cfm cam in the .770ish range should get you there. Your well on your way buddy.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: JACK1440]
#2044448
04/02/16 02:22 PM
04/02/16 02:22 PM
AndyF
Nick did set the heads up completely from machine work to springs and retainers. He set everything up for the .750 lift comp roller he had ground for the last motor. Not sure if the retainers are correct for the higher lift. I do know I would have to go to the next comp spring to get past the coil bind. Maybe it's best like you said to have them looked at by a pro. Okay, if you already have a complete combo designed to work at .750 then I'd bolt it together and run it. It might make the power that you need and it might not but you might as well try it. Run it a season and then you'll know.
[Re: JACK1440]
#2044531
04/02/16 04:41 PM
04/02/16 04:41 PM
Posts: 43,251 Bend,OR USA
Cab_Burge
I finished dyno testing a 511 C.I. 400 iron block stroker motor for a local customer yesterday with a set of Indy 440 EZ M.W. intake port size heads, I don't know how to tell if thier the 295 or 345 versions , with a old Comp Cams solid lifter cam, 275@.050 with .635 net lift with checking springs, 12.0 to 1 compression on 108 octane race gas. I was disappointed with the 655 HP it made with a Indy 400-2 intake and the Proform 950 CFM carb. I tried a Holley 1050 CFM Dominator with the tapered adapter and it didn't pick up 2 hp with simialr AFR I should have used a set of 440-1 CNC ported heads I have on that short block instead of those EZ Hindsight is always 20/20
[Re: JACK1440]
#2044548
04/02/16 04:59 PM
04/02/16 04:59 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Cab, EZ heads can make good power, but if you're running basically ootb EZ-1's, you're definitely leaving power on the table. If that motor had CNC 295's or 325's on it, it should have made quite a bit more power than that.
My feeling for the OP's build...... 345cfm EZ's (from my bench) would represent mildly cleaned up heads. Not what I would use if I were anticipating making 800hp. That being said, I'd still use them as is, with a suitable cam that will work with the hardware that's already on the heads. Save your money and use it towards bigger heads that are more in line with those power levels(800hp+).
