Rust on Trunk Lid #204281
01/25/09 06:37 PM
01/25/09 06:37 PM
CA
David Lee Offline OP
CA
I just pulled off my cuda's trunk lid and noticed there was rust on the inside where I could not get a sander. What is the remedy to get rid of this rust. Find a place that can dip it?
Re: Rust on Trunk Lid [Re: David Lee] #204282
01/25/09 06:50 PM
01/25/09 06:50 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Dipping would be the best...Being a garage kept California car it probably is more surface rust than anything to be seriously concerned about....That being the case look it over good & you could probably get away with pouring Rust-Bullet into the openings & rotate the decklid around so everything gets a good coating...
Re: Rust on Trunk Lid [Re: 1_WILD_RT] #204283
01/26/09 01:35 PM
01/26/09 01:35 PM
Millersville, PA
HemiChallenger Offline
Millersville, PA
What i would do is buy a product to kill rust such as rust bullet. Then buy a wand that you stick down in the hole and it sprays the product 360* around and it will cover it. But the surface rust i dont think that it will be needed to do that...
Re: Rust on Trunk Lid [Re: HemiChallenger] #204284
01/26/09 04:43 PM
01/26/09 04:43 PM
Silicon valley
A12bee Offline
super street
A12bee  Offline
super street
Silicon valley
I use the Must for rust on my entire car. It's a water based product that you can get from home depot. Works great, envro friendly and you don't get the build up like you get from rust bullet or the like.
This space left intentianlly blank.
Re: Rust on Trunk Lid [Re: A12bee] #204285
01/26/09 10:29 PM
01/26/09 10:29 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
if it's a mint lid, I would send it out to get dipped/stripped...that stuff seams to flow everywhere..
Re: Rust on Trunk Lid [Re: AARCONV] #204286
01/27/09 06:37 PM
01/27/09 06:37 PM
CA
CA
That's what I leaning towards. Right now I am just removing the surface rust and will coat it with epoxy primer. When I get the doors and fenders pulled at a later date I will bring everything down to a stripper in Santa Ana.
