Valve Lash with Scott Brown flat Tappet cams? #204261
01/25/09 06:16 PM
01/25/09 06:16 PM
Houston, Texas
FastOrange Offline OP
Houston, Texas
I've been out of the game for awhile and lost my cam card. I've got an aluminum headed 440 with a Scott Brown flat tappet solid cam. I can't remember what to set the valve lash clearance at.
BTW, where is Scott Brown these days??
Re: Valve Lash with Scott Brown flat Tappet cams? [Re: FastOrange] #204262
01/25/09 06:44 PM
01/25/09 06:44 PM
NC
440Jim Offline
440Jim  Offline
NC
Well, I have no way of knowing exactly which lobe profiles you have, but the ones on my SB flat tappet solid lifter cam was 0.014" Intake, 0.020" exhaust. That is a tight lash intake lobe!
Re: Valve Lash with Scott Brown flat Tappet cams? [Re: 440Jim] #204263
01/25/09 07:23 PM
01/25/09 07:23 PM
Houston, Texas
Houston, Texas
Cam is a 254/266. Lift is something like .620/.580. I have lash at .013"/.015" in my notes but that sounds pretty tight. That's why I asked. It's been several years and I'm getting older
Re: Valve Lash with Scott Brown flat Tappet cams? [Re: FastOrange] #204264
01/25/09 07:30 PM
01/25/09 07:30 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
I have a cam from Scott similar to yours and mine is .014 I and .016 Exh
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
