Re: Small Block 90* Oil Filter Adapter????
[Re: mopars4ever]
#2042631
03/31/16 12:14 PM
03/31/16 12:14 PM
Posts: 4,980 new jersey usa
11secdart
new jersey usa
I got one from Mancini Racing a year or so ago, give them a try.
[Re: 11secdart]
#2042781
03/31/16 04:19 PM
03/31/16 04:19 PM
Posts: 11 North Dakota, USA
74Beeper
North Dakota, USA
I got one from Mancini Racing a year or so ago, give them a try. They no longer offer them. Thanks though.
[Re: mopars4ever]
#2042864
03/31/16 06:23 PM
03/31/16 06:23 PM
Posts: 11,572 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
http://www.ebay.com/itm/Mopar-Performance-Right-Angle-Oil-Filter-Adapter-P5249624-1967-91-Small-Block-/221998985430?hash=item33b02bb0d6:g:7ycAAOSwLnlWnVxa&vxp=mtr 80 bucks. Don't know if that's a deal. Haven't bought one for years. No bolt with it. I did see a bolt at another place for $60. I don't understand. It's still showing in the Mopar Performance catalog along with R3s and other goodies. Are you telling me that the catalog is not up to date?
[Re: slantzilla]
#2042965
03/31/16 08:56 PM
03/31/16 08:56 PM
Posts: 6,142 Melbourne , Australia
LA360
I have one that belongs to a friend in my garage somewhere. No centre bolt for it though. I didn't think anyone over here in Aus would buy it, so I haven't done anything with it.
Alan Jones
[Re: LA360]
#2042985
03/31/16 09:27 PM
03/31/16 09:27 PM
11secdart
new jersey usa
The bolt and the gasket set used to be available for sale as two different part numbers as well as the entire assembly. There was two different bolts available over the years one with the oil passages next to each other and one with the passages staggered , the one with the staggered passages is stronger, ask me how I know?
[Re: 74Beeper]
#2043178
03/31/16 11:54 PM
03/31/16 11:54 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
There are a few bolts out there still for sale for $60 give or take. That could be made. The adapters are scarce. How can MP stop doing these?
Nevermind. Dumb question.
[Re: 74Beeper]
#2043261
04/01/16 01:28 AM
04/01/16 01:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Put a remote filter on it.. way easier to change the filter and you end up with more oil in the system just make the lines big enough EDIT you can buy all the parts needed from Summit.. the plate that mounts on the engine and the remote filter set up.. make your own lines with a radiused turn for flow ALSO..on a R3 dont you have the mains priority oiling (the inlet of the oil at the front china rail)
[Re: MR_P_BODY]
#2043366
04/01/16 10:11 AM
04/01/16 10:11 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Put a remote filter on it.. way easier to change the filter and you end up with more oil in the system just make the lines big enough EDIT you can buy all the parts needed from Summit.. the plate that mounts on the engine and the remote filter set up.. make your own lines with a radiused turn for flow ALSO..on a R3 dont you have the mains priority oiling (the inlet of the oil at the front china rail) Also CV products has a billed one if so desired. Andy F has used a set of extentions on his 427 small block build. I think the company is Bo Laws Performance. Matt
[Re: MR_P_BODY]
#2043598
04/01/16 03:48 PM
04/01/16 03:48 PM
74Beeper
North Dakota, USA
Put a remote filter on it.. way easier to change the filter and you end up with more oil in the system just make the lines big enough EDIT you can buy all the parts needed from Summit.. the plate that mounts on the engine and the remote filter set up.. make your own lines with a radiused turn for flow ALSO..on a R3 dont you have the mains priority oiling (the inlet of the oil at the front china rail) It an R3 Siamese bore 340 Resto block.... Externally it looks pretty much the same as any 340 block, internally is a different story.
[Re: 74Beeper]
#2043609
04/01/16 04:00 PM
04/01/16 04:00 PM
MR_P_BODY
Put a remote filter on it.. way easier to change the filter and you end up with more oil in the system just make the lines big enough EDIT you can buy all the parts needed from Summit.. the plate that mounts on the engine and the remote filter set up.. make your own lines with a radiused turn for flow ALSO..on a R3 dont you have the mains priority oiling (the inlet of the oil at the front china rail) It an R3 Siamese bore 340 Resto block.... Externally it looks pretty much the same as any 340 block, internally is a different story. I'm not sure about the resto block.. I assume it oils just like a stock block so you wont have the front oil inlet
[Re: MR_P_BODY]
#2043738
04/01/16 06:26 PM
04/01/16 06:26 PM
74Beeper
North Dakota, USA
Put a remote filter on it.. way easier to change the filter and you end up with more oil in the system just make the lines big enough EDIT you can buy all the parts needed from Summit.. the plate that mounts on the engine and the remote filter set up.. make your own lines with a radiused turn for flow ALSO..on a R3 dont you have the mains priority oiling (the inlet of the oil at the front china rail) It an R3 Siamese bore 340 Resto block.... Externally it looks pretty much the same as any 340 block, internally is a different story. I'm not sure about the resto block.. I assume it oils just like a stock block so you wont have the front oil inlet What is this front oil inlet you're referring to? What is it's purpose?
[Re: justinp61]
#2043746
04/01/16 06:41 PM
04/01/16 06:41 PM
74Beeper
North Dakota, USA
It's a passage in the front china wall that goes straight down to the main oil passage that runs along the lifter bores and feeds the mains. My R1 has the boss but is not drilled. It must have it.... The only difference between the R3 race and R3 resto is the extra head bolt bosses are milled off of the resto. You can see on my block where they were shaved.
