Transmission problems #2042362
03/30/16 11:49 PM
03/30/16 11:49 PM
Id
mopeman Offline OP
mopeman  Offline OP
Id
Ok, I got a new to me 1990 4x4 Dakota with the 3.9 v6/auto. Truck runs pretty good, still needs a tune-up, filters and fluids. Anyway, the trans is acting funny, when it is put into reverse, it will start to move then stop or if it starts moving it will start to jerk around. It will go if the gas is applied but has a hard time moving/going. The other funny thing is it has no neutral setting, it will go from reverse straight into drive! All fwd gears shift like they are suppose to and can be manually shifted too. It will engine brake while shifting the gears down and slow the truck like it should. I have started my investigation and have come up with nothing. At first I thought it was the rear drums binding, nope, pulled the drums and the actually needed adjusted. Pulled the drive shaft and checked the diff and u-joints, still nothing. Then with the drive shaft off, I started the truck and it would do the same thing...so it must be the transfer case or the trans itself. I also put the transfer case in neutral and it would still do the same as before. The transfer case does have fluid. I plan on pulling the trans pan this weekend, changing the fluid and filter and checking the band adjustments. So, does anybody have a clue?
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: Transmission problems [Re: mopeman] #2042390
03/31/16 12:11 AM
03/31/16 12:11 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
If you have ALL the forward gears the problem is likely with the forward clutch pack. It sounds like it is not releasing for some reason. If I were to guess, the forward clutch pack is probably fried. The clutches and steels will be either severely warped or possibly welded together. I'd pull the pan and see how much debris is in the pan. If there is a bunch of trash lying in the bottom, it's going to be rebuild time.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Transmission problems [Re: 71yelladustr] #2042684
03/31/16 01:42 PM
03/31/16 01:42 PM
Guitar Jones Offline
Forward clutch pack is not the same as the front clutch pack. He actually means the rear clutch pack which is engaged in all forward gears. It is released in neutral and reverse. The front clutch pack is engaged in reverse, 3rd and O/D.
Re: Transmission problems [Re: Guitar Jones] #2042849
03/31/16 05:59 PM
03/31/16 05:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Forward Clutch" is a GM/Ford term. tsk Please try to speak only Mopar here.
Re: Transmission problems [Re: mopeman] #2043250
04/01/16 01:12 AM
04/01/16 01:12 AM
Missouri U.S.A.
Missouri U.S.A.
My mistake Mr. Kunkel.
10.02@134
Re: Transmission problems [Re: mopeman] #2043269
04/01/16 01:47 AM
04/01/16 01:47 AM
Id
mopeman Offline OP
mopeman  Offline OP
Id
So if I have to rebuild it, it's a 42rh or 500a correct?
Mopar or no car
'93 W250 Ram
'68 Charger
