Re: Looking for new upper control arms for a 79 D100
[Re: moparjoe360.4]
#2035754
03/21/16 02:50 PM
03/21/16 02:50 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
This may not be compatible, but here it goes.
I went to rockauto.com and bought new van lower control arms for my Ramcharger. They allow me to lower the front of the truck without changing the springs, because they fit the springs into pockets rather than on top of the arm. Their catalog lists new upper control arms for the vans, but not for the pickups so the mounting points and geometry of those may not help you at all. Someone will have to do more research, but it is a place to start. And they are relatively cheap.
Good luck.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: BulletBob]
#2039866
03/27/16 05:42 PM
03/27/16 05:42 PM
Polarapete
Graham, WA
Now I know that I need to save my existing upper control arms and replace the upper balljoints when I do the lower control arm swap on the Ramcharger. It is kind of nice to have two trucks of the same era to work with. I should have saved more of the parts off the Ramcharger when I stripped it for racing, but the only thing I have used off that and put on the D100 has been the clutch fan.
[Re: timeklr]
#2041295
03/29/16 05:39 PM
03/29/16 05:39 PM
Polarapete
Graham, WA
I would be interested in what you find in your research.
