Re: Speedometer Gear Question
[Re: mopowers]
#2041506
03/29/16 10:55 PM
03/29/16 10:55 PM
RapidRobert
I'd post how long is the shank. I'm thinking there are only several varieties of em so with that dimention I think the guys here can ID it right away
[Re: Pacnorthcuda]
#2041600
03/30/16 12:29 AM
03/30/16 12:29 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Yes, that is an early long shank speedo gear. It will fit your 68 tranny no problem. Awesome! Thanks man
[Re: mopowers]
#2041629
03/30/16 12:59 AM
03/30/16 12:59 AM
Posts: 4,285 Ohio
64dodge572
Ohio
The shaft recess in the reproduction gears aren't deep enough to accept the manual speedo cable, that is why they are listed for the electronic sensor and not the earlier cable driven applications. The company that reproduced them didn't verify fitment before making thousands of them.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 64dodge572]
#2041651
03/30/16 01:30 AM
03/30/16 01:30 AM
mopowers
Sac, CA
The shaft recess in the reproduction gears aren't deep enough to accept the manual speedo cable, that is why they are listed for the electronic sensor and not the earlier cable driven applications. The company that reproduced them didn't verify fitment before making thousands of them. That makes sense. How far off are they? Would trimming the speedo cable make it usable? How bout swapping shafts from an old one? I've heard its just a slight press fit. Not sure if it's true though.
[Re: mopowers]
#2041662
03/30/16 01:48 AM
03/30/16 01:48 AM
Posts: 4,285 Ohio
64dodge572
Ohio
Gears are molded on a knurled shaft, not removable. Good luck trimming the cable without fraying it.
[Re: 64dodge572]
#2041664
03/30/16 01:55 AM
03/30/16 01:55 AM
mopowers
Sac, CA
Gears are molded on a knurled shaft, not removable. Good luck trimming the cable without fraying it. That's a bummer. Thanks for the info. I appreciate it.
[Re: 64dodge572]
#2042038
03/30/16 04:05 PM
03/30/16 04:05 PM
mopowers
Sac, CA
The shaft recess in the reproduction gears aren't deep enough to accept the manual speedo cable, that is why they are listed for the electronic sensor and not the earlier cable driven applications. The company that reproduced them didn't verify fitment before making thousands of them. Damn, you're right. I called on a new reproduction one and the recess for the cable is only 5/8" as opposed to 1-1/8" in my old one. Does that mean I'm reduced to looking for a used 37 tooth gear? Or does someone reproduce an accurate original that I can use a cable with?
[Re: stumpy]
#2042395
03/31/16 12:13 AM
03/31/16 12:13 AM
mopowers
Sac, CA
I just did a search for mopar 37 tooth speedo gears on ebay and a bunch of sellers of used gears showed up. None of them have 37 tooth gears. They just put all the numbers in the title of their ad so they show up. Its BS. I guess I'll just have to be on the lookout.
