What's a 1977 Van based RV weigh....?
#2041391
03/29/16 08:37 PM
03/29/16 08:37 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I have a 1977 van based RV I want to tow on my tandem axle car trailer....What does this van weigh any idea?....I'm guessin the trailer is good for a bout 7000 lbs. 2-5 lug axles. I want to buy the low milage 360 drivetrain for my 82 318 D250 and the guy wants the whole thing gone.
Is this a good idea or not? Thanks Rick
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: What's a 1977 Van based RV weigh....?
[Re: HemiRick]
#2041496
03/29/16 10:46 PM
03/29/16 10:46 PM
Posts: 10,585 Freeport IL USA
poorboy
Freeport IL USA
Van based RVs have a box added to the back end of the unibody frame to support the added RV structure. The added part is pretty good stuff, but its still added to the van's boxed sheet metal rear crossmember (most are bolted to the rear crossmember).
You will want to look at the condition of the rear van crossmember (about 2' behind the rear axle) and be sure it is still in good shape, especially if there is already a trailer hitch on the RV. The RV will do OK towing a trailer, but the rear frame is a bit weak to support a large tongue weight trailer. If your intending on towing a box trailer, or one with a lot of tongue weight, I suggest you invest in the bus style RV.
I'm only a welding shop guy, I've had a lot of van style RVs in because "the trailer hitch is drooping towards the ground more then it was". Sometimes they can be braced, sometimes they can't. A car trailer is at the limit, in my opinion. Gene
[Re: HemiRick]
#2041693
03/30/16 02:48 AM
03/30/16 02:48 AM
HemiRick
Memphis
Thank you Stumpy, Poorboy does this mean if I want to remove the RV part, to decrease the weight of this thing, That it can unbolted/cutoff at this rear crossmember? I'm pondering the idea of cutting this RV apart where it is and promising the man to come back and clean up the mess.
[Re: HemiRick]
#2042247
03/30/16 09:10 PM
03/30/16 09:10 PM
Posts: 5,846 ohio
ruderunner
ohio
Is this a van with a high top roof or an actual "mini Winnie"? Either way you're going to need a bigger trailer and something to pull it.
Beware if it's a mini winne style, most scrap yard won't take em since there's too much wood and plastic in em.
Angry white pureblood male
[Re: HemiRick]
#2042270
03/30/16 09:52 PM
03/30/16 09:52 PM
HemiRick
Memphis
It's the mini wini w the bed over the cab.....I guess we are going to cut it up where it is and go back and clean up the mess after we get the chassis home.
