Page 6 of 7 1 2 3 4 5 6 7
Re: 318 for drag race use [Re: 318 racer] #2041059
03/29/16 10:54 AM
03/29/16 10:54 AM
Charlotte, NC
LSP Online content
LSP  Online Content
Charlotte, NC
Typical bracket guy isn't going to build a 318, bracket guy wants to go as big as he can as cheaply as he can.
A bracket 318 could have a head with 50+ cfm, and 3 points more compression than a Super Stock 318. $7K-ish would get it done.
Re: 318 for drag race use [Re: LSP] #2041076
03/29/16 11:28 AM
03/29/16 11:28 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Oh so true...
Re: 318 for drag race use [Re: Quicktree] #2041159
03/29/16 01:50 PM
03/29/16 01:50 PM
fla
ss/la Offline
ss/la  Offline
fla
need to adjust your prices a little
heads and intake port work 7500.00
jesel or t&d 1600.00
valve springs 600.00
rings 600.00
piston 1200.00
cam & lifters 1200.00
if you get it right the first time
custom convertor 1200.00
carb mods 500.00
machine work about the same
Re: 318 for drag race use [Re: LSP] #2041169
03/29/16 02:02 PM
03/29/16 02:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I for one cannot see it taking 20 grand to make 545 hp out of a 318, a stocker, yes because they have to work with "stock" parts, no comp, stock 400? lift, stock intake. But ported heads, big roller cam, high comp pistons, with today's technology I think it would be easy but a very peaky engine with much rpm. 340 stocker engines are turning 7500 with stock J heads and intake with a TQ. Just read about a 273 running mid tens(and not a D Dart). Go for it, compression will be your friend.
Re: 318 for drag race use [Re: LSP] #2041198
03/29/16 02:43 PM
03/29/16 02:43 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
Originally Posted By v cummins
Keep in mind that a ss gt 318 is a short stroke big bore to make 318 ci.
No, stroke is only allowed to be +/- .015" from stock, and bore is allowed to be no more than .080" over stock.
Ya i may be thinking of mod/ss they only P&G they don't check bore & stroke. unless its over ci
Re: 318 for drag race use [Re: cudaman1969] #2041202
03/29/16 02:50 PM
03/29/16 02:50 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
A .060 over 318 would need 1.66 hp per cube to reach 545 horse, since we are NOT required to follow the paramaters of a superstock engine. How could a 328 cube engine with ported Ed heads, a .720 lift solid roller, Jesel or T&D paired shafts, and 13.5:1 compression not reach 545 horse at a reasonable cost?
I dont understand the doubting. As far as the rpm ceiling, way way back, my pops bracket raced a 340 powered car every week, shifted at 7200 and traped at 7300, had TRW 10 pound dome slugs, STOCK rods, Crane ductile iron rockers, and a flat tappet cam. So a 318 with strong lightweight honda journal rods, lightweight pistons and pins, thin ring pack, titanium retainers, roller cam and paired shaft rockers with excellent geometry there is no reason it couldnt withstand 7600-7800 reliably
Re: 318 for drag race use [Re: GTS340] #2041219
03/29/16 03:20 PM
03/29/16 03:20 PM
fla
ss/la Offline
ss/la  Offline
fla
it realy is irrelivent weather it is a stocker a super stocker or a bracket engine the same basics hold true,how efficient of an air pump can you build? it takes ring seal,cylinder pressure, and reduction of parasitic drag those factors will tell the story
when you figure out how to master those items you will learn to go fast grasshopper
Re: 318 for drag race use [Re: ss/la] #2041236
03/29/16 03:50 PM
03/29/16 03:50 PM
408Dust Offline
408Dust  Offline
[quote=ss/la]it realy is irrelivent weather it is a stocker a super stocker or a bracket engine the same basics hold true,how efficient of an air pump can you build? it takes ring seal,cylinder pressure, and reduction of parasitic drag those factors will tell the story
But master I thought it could be done for less then 7,000. Buy off the shelf parts have your local Napa do the machine work bring it home put it together and poof its magic dang it...
Re: 318 for drag race use [Re: 318 racer] #2041253
03/29/16 04:32 PM
03/29/16 04:32 PM
AndyF Offline
AndyF  Offline
Originally Posted By 318 racer
First post here..
I'd like to build a 318 for drag race use. Max 8000 rpm.Would like to know what you guys would use for all parts for the build. However there are 2 items the engine must use...
Edelbrock cylinder heads
ThermoQuad carburetor.
No it's not a NHRA/IHRA engine for class racing,but would like to build along those parameters.
Cam,intake header size,crank,rods pistons,oiling system etc... what would you use?
Engine will be in a A-body Duster.
Give Bob Mazzolini a call. He raced a 318 for a long time. Cast crank, low compression, QJet, etc. I think he ran 10's in a Sebring. He was selling off that stuff last time I talked to him, not sure if he still has a pile of parts or not. I think he was using a factory cast iron head so you're ahead of the game there.
From what I recall, Bob's car weighed 3200 lbs and ran 10.30's so he was making roughly 570 hp. That was a class car, GT/IA or something like that. He was 9:1 compression and iron heads so if you switch to aluminum heads and take the compression to 13:1 or so you should be able to get by with much less expensive headwork. Cam might be a little different due to the higher compression ratio but most everything else would be the same.
Re: 318 for drag race use [Re: 408Dust] #2041271
03/29/16 05:06 PM
03/29/16 05:06 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
d
Agree, apples and oranges in parts-price
Re: 318 for drag race use [Re: AndyF] #2041318
03/29/16 06:17 PM
03/29/16 06:17 PM
fla
ss/la Offline
ss/la  Offline
fla
a little off on the weight and horsepower less weight and less horsepower
Re: 318 for drag race use [Re: 318 racer] #2041384
03/29/16 08:26 PM
03/29/16 08:26 PM
Georgia
3
318 racer Offline OP
Georgia
I'm not building a GT engine. Sure I'd like to,but the wallet and life in general says no.
I'm using what I have,and buying what I dont.
I'm going to build it. If I go 10.90's I'll dance the 2 step boogie.
I'll be very honest..part of the reason too is my first car was a 318 Duster. I did the usual bolt on's and it ran 14.20's. What I liked was that those I beat,were surprised and embarassed they got beat by a 318.
Re: 318 for drag race use [Re: 318 racer] #2041390
03/29/16 08:36 PM
03/29/16 08:36 PM
Charlotte, NC
LSP Online content
LSP  Online Content
Charlotte, NC
Grasshopper may be younger than you, but is no spring chicken.....Kwai Chang Kane been involved in Super Stock many moons, and build engine from time to time. Latest offering has taken the pebble from your hand many times on qualifying sheet.
Re: 318 for drag race use [Re: 318 racer] #2041428
03/29/16 09:29 PM
03/29/16 09:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I think most on here are just not only trying to keep your costs down but trying to help you get more bang for your buck. If you keep an open mind and grab parts for the right price 10.50's can be had on a budget. The last block (340), Scat rods, Diamond pistons, Scat cast crank (4" stroker), cam and lifters, timing chain and gears, new rings, and Milidon oil pan and pick-up cost me 1350 dollars. Its all machined and balanced ready to assemble. Deals are out there and I promise you this one will be faster than 10.50's. Lets see how much that 318 costs to run the same. Same with heads. I've found sets of Edelbrock heads (some on this site) for 500-800 dollars per pair. Be ready for when the deal comes strolling by.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 318 for drag race use [Re: LSP] #2041584
03/30/16 12:04 AM
03/30/16 12:04 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Ok so you're talking Super Stock, his weight at 3200 puts a 340 car in E or F class. The current records for SS/D-9.07. E-9.24. F-9.33 G-9.46, that's porting the heads, any cam, stock compression any 4 barrel intake and stock factory carb. I'm sure that takes big bucks to massage those parts to the hilt. So if he puts the same money in his 318 (22 ci less) why couldn't he run high nines? For a lot less money 10.70 will be easy. $7500 to port a set of heads and intake, that's 150 hours, likes 10 hours being a month, 8 hours a day for 19 days, somebody's getting ripped.
Re: 318 for drag race use [Re: 318 racer] #2041606
03/30/16 12:33 AM
03/30/16 12:33 AM
Georgia
3
Georgia
I get that and trust me..I REALLY appreciate all the insight. Hey we have 6 pages of info! More than I ever thought would happen,and that's off of my first post here. Now you guys know why I came here FIRST.
Still going to build the 318 and see what it will do. No GT racing though...too expensive.
Re: 318 for drag race use [Re: 318 racer] #2041732
03/30/16 08:26 AM
03/30/16 08:26 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
318 racer... I posted a thread a good while back about building a Magnum smallblock, and it ended up with a pile ov neat info. I cant remember exactly which thread ov mine it was, but search my threads and it'll be there. In it i remember someone talking about a pretty obscene 273 build. I think it started with that article (Mopar Muscle???) about the 455HP stock Magnum 360 short block/Edelbrock top end build. I think if people would just forget that the term 'super stock' ever entered the conversation, ideas about costs would remain a lot more reasonable. I've seen some truly junk [censored] all-out FLY around here... and i am stuck dead-center in Chevy and Mustangland.
Re: 318 for drag race use [Re: cudaman1969] #2041750
03/30/16 09:56 AM
03/30/16 09:56 AM
Charlotte, NC
LSP Online content
LSP  Online Content
Charlotte, NC
I was jumping in on the Kung Fu TV show themed banter, was supposed to be funny, guess I shouldn't quit my day job lol.
A 71 340 in an A body will only fit in I, J, or K in Super Stock.
Re: 318 for drag race use [Re: 318 racer] #2041774
03/30/16 11:02 AM
03/30/16 11:02 AM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
So 318 it is lets start with the blocks. what years. you will want to tar them all down and have them checked.
I would rather see you at 20 or 30 over and have a stable hole.
Re: 318 for drag race use [Re: v cummins] #2041997
03/30/16 03:13 PM
03/30/16 03:13 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Sounds like a fun build, but I would vote for a 4" crank as well. A cast mp or scat crank would work well and they only cost about $350 and add 50 cubes. It would make more power and be much more reliable.
Another thing to add is that for bracket racing the high winding sb can be a nightmare to keep consistent et round for round. They are more sensitive to atmosphere conditions and shift points.
A stroker will also be much less sensitive to gearing and stall. As for these thoughts the op can take it or leave it.
A high winding 318 would be fun, but much less reliable and more expensive in the long run.
