Re: Engine bolts
[Re: can.al]
#2041347
03/29/16 07:11 PM
03/29/16 07:11 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If it's a stock motor you should be fine with the factory hardware. If it's something that is going to be driven with enthusiasm then you'll need to swap head, rod, and main bolts.
It's cheap insurance on any build.
Re: Engine bolts
[Re: Stanton]
#2041366
03/29/16 07:54 PM
03/29/16 07:54 PM
feets
Senior Management
Senior Management
Irving, TX
Heads and mains should be fine. I like the idea of replacing rod bolts BUT that has to be done before and only if you're resizing the big end. Correct. Again, if you plan on driving with enthusiasm it is a necessary evil.
Re: Engine bolts
[Re: can.al]
#2041456
03/29/16 10:12 PM
03/29/16 10:12 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
...For a rebuild,which bolts would you definitely not re-use? ...head bolts...rod bolts..main cap bolts??? Factory bolts... Heat-cycled, stretched, and stressed who knows how many times... Bolts... New bolts... Better to have them, than wish you did...
Re: Engine bolts
[Re: 451Mopar]
#2041602
03/30/16 12:29 AM
03/30/16 12:29 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
[snip]... I have had issues with the stock 1/4 bolts breaking (valve covers, and other places they might be used?) That's likely from me over tightening them. ...and because of the weird 7-degree angle big-block valve covers screws are installed at! Rick
Re: Engine bolts
[Re: can.al]
#2041626
03/30/16 12:58 AM
03/30/16 12:58 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
If your going to do a stock type build with rings, bearings, valve job and maybe a little bigger cam I would take the rods with the stock bolts torque to 45 ft lbs with oil to someone who has a good dial bore gauge and have them check the roundness of the rods(all 8) big end bore. If they are all round I would, and have many times, reuse those rods and put the money for the new rod bolts and resizing the big end of the rods to a better use If you don't know the history of the motor and you have ANY doubts about reusing the rods or bolts swap them out
