A body guru help needed. 71 340 duster data tag ??? #2041346
03/29/16 07:11 PM
03/29/16 07:11 PM
Richmond County!
SIMopar Offline OP
SIMopar  Offline OP
Richmond County!
I'm looking a a 71 340 duster H code car. On the vin tag is the A51 code
I was under the belief that the A51 code was the Twister package and limited to 318 cars??
Thanks. For any clarification
Kevin
Re: A body guru help needed. 71 340 duster data tag ??? [Re: SIMopar] #2041356
03/29/16 07:31 PM
03/29/16 07:31 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
A51 - 71 Twister
A62 - Rallye Gauges
I would question both those codes but I'm not a 71 A Body expert
Re: A body guru help needed. 71 340 duster data tag ??? [Re: SIMopar] #2041416
03/29/16 08:57 PM
03/29/16 08:57 PM
Gabba Gabba Hey! NYC
Diego (not Ted) Offline
Twister is /6 or 318 only.
Re: A body guru help needed. 71 340 duster data tag ??? [Re: SIMopar] #2041436
03/29/16 09:42 PM
03/29/16 09:42 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
You got a clearer picture of the tag?
Careful, your character's showing!
Re: A body guru help needed. 71 340 duster data tag ??? [Re: SIMopar] #2041445
03/29/16 09:59 PM
03/29/16 09:59 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Car has almost all of the most desirable options too
Investigate this one deeper in person. That first and second row could be a little wonky.
When the stars seem to be perfectly aligned....be skeptical, be more skeptical.
Engine and trans numbers? If so, what do they look like?
Radiator support numbers? Area around numbers? Upper to radiator opening to inner fender panel join and spot weld condition and look?
Speaker tray stampings pic match radiator support?
That's just cracking the egg.
Re: A body guru help needed. 71 340 duster data tag ??? [Re: SIMopar] #2043292
04/01/16 03:45 AM
04/01/16 03:45 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
fake tag?
5549 post on old board
Re: A body guru help needed. 71 340 duster data tag ??? [Re: 05dakota] #2043294
04/01/16 03:46 AM
04/01/16 03:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By 05dakota
fake tag?
scope
