Re: Biggest rear tire 67-69 barracuda
[Re: sshemi]
#2041319
03/29/16 06:18 PM
03/29/16 06:18 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#2041321
03/29/16 06:26 PM
03/29/16 06:26 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
A 28" is VERY close to the front on mine and rubs a little on the fender well on the outer side.
I run a 275/50 though with no problems. If my car was a race car I could get away with a 275/60 but with as low as it sits and since I drive it on drag week loaded with crap I need the shorter tire.
Stock width 8.75 with a 3 5/8 back space wheel.
This pic is with the 275/50 I am looking for a pic with 275/60s
68 Barracuda Formula S 340
[Re: sshemi]
#2041322
03/29/16 06:32 PM
03/29/16 06:32 PM
Bad340fish
Tulsa OK
This was with the MT 275/60/15 Pro Radial. Looked good but hit on a bump up inside the fender. I need to raise the car up.
I do not know why the pic shows up at this angle.
[Re: Bad340fish]
#2041340
03/29/16 07:02 PM
03/29/16 07:02 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
I do not know why the pic shows up at this angle. I can fit a 275/60 on my 68 fish also. What brand/model is that wheel?
[Re: Airwoofer]
#2041343
03/29/16 07:09 PM
03/29/16 07:09 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I'm running a MT 28x10.5 on my 1968 but that's a slick not street tire. Just mounted a set of the new MT Pro Bracket 28x10.5 radial slicks today and they also fit. Stock length 8 3/4, stock spring location. I am running 1/2" spacer on the driver side and 3/8 on the passenger side because they were rubbing the Cal-track mono leaf spring.
[Re: Bad340fish]
#2041405
03/29/16 08:47 PM
03/29/16 08:47 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
I run a 275/50 though with no problems. If my car was a car car I could get away with a 275/60 but with as low as it sits and since I drive it on drag week loaded with crap I need the shorter tire.
This pic is with the 275/50 I am looking for a pic with 275/60s nice car
[Re: Airwoofer]
#2041557
03/29/16 11:42 PM
03/29/16 11:42 PM
Bad340fish
Tulsa OK
I do not know why the pic shows up at this angle. I can fit a 275/60 on my 68 fish also. What brand/model is that wheel? It is a Holeshot brand Holestar wheel on the rear. I have Billet Specialties Street Lights on the front. The holeshots are very light and the fronts got some cracks in them so I had to move to an actual street rated wheel(only 2 lbs heavier).
[Re: one bad fish]
#2041561
03/29/16 11:46 PM
03/29/16 11:46 PM
Bad340fish
Tulsa OK
nice car[/quote] Thank you!
