Yes, More Broadcast Sheet Questions
#204124
01/25/09 03:31 PM
01/25/09 03:31 PM
Posts: 21 N. Georgia
Iko
N. Georgia
Hello again, thanks to everyone, I am getting some help! I have run my fender tag through a few decoders and have been trying to piece back together my build sheet (I modified the 71 one with all of the info I can salvage), but there are some inconsistencies. I have the original punch card in great shape, I just need to get it read somewhere. Maybe someone can help, is the Heritage Museum the only place that can read them? I am finding some inconsistencies with the decoder values for some codes and I think it is because most of them go to '71 and I ave a '74. The best one I have found so far is at Broadcast Sheet Codes but I do have a question about the B41. Does it mean that my RR originally came with 10" rear drums, or are most of the decoders I've found using older codes? The site I found above doesn't have anything about the rear drum on a B41, that might be why I like it. I also have a note on my Broadcast Sheet stating, "94 OIL UNIT", what is that? Okay, these are my questions: Can I have my "IBM Punch Card" broadcast sheet run somewhere to produce a new one? Where can I find the most comprehensive lists of MOPAR broadcast sheet Codes? Can someone point me toward help on reading the notes section of the broadcast sheet? Thanks everyone for the help!!!
Re: Yes, More Broadcast Sheet Questions
[Re: Iko]
#204125
01/25/09 05:05 PM
01/25/09 05:05 PM
Okay, these are my questions: Can I have my "IBM Punch Card" broadcast sheet run somewhere to produce a new one? Find someone that used to do "key punch" back in the day. Where can I find the most comprehensive lists of MOPAR broadcast sheet Codes? Galen Govier's white books. Can someone point me toward help on reading the notes section of the broadcast sheet? No where that I know of you have to figure them out for your self and most are self explainitory.
B41 is the is the sales code for "front disc brakes with standard 10" rear drum brakes. Most hipo cars cam standard with 11" drums front and rear, but when discs were ordered they though that 11" rears were not necessary and it also had something to do with the proportioning valve compatibility.
#204127
01/26/09 11:46 AM
01/26/09 11:46 AM
Iko
N. Georgia
Thanks for the reply! I am a computer guy by trade so reading it is not the issue, it is the program that interpolates what is read from the card. I'd love to get a copy of the code that was used there, I'd start building build sheets Chrysler Historical said they couldn't help here because I have a RR built in 74. I guess their records only go to 68. I think they might have misunderstood me though because I have the record, I just need someone to read it. I think I might break down and buy the Galen Govier book. It would be good to have. As for the brakes, the build sheet states that it is RR Size B25 and Disk B41 on the sheet. I thought all Roadrunners came with the HD brakes, but I could be wrong. That is another reason I would like to know the exact 74 build codes. The EBay auction mentioned below is also a B41 brake on that 74 with the 360. Again thanks for all of the help, you all are making this hobby a little easier!
[Re: lakerism]
#204131
01/26/09 02:21 PM
01/26/09 02:21 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
B41 on a 70-74 ebody is the code for disk-brakes, this code only appears on the build-shhet but not the fender tag.
Whether it appears on the tag or not depends on the year. What does and does not appear on a tag varies by plant, year and sometimes even time of year.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#204132
01/26/09 02:47 PM
01/26/09 02:47 PM
Iko
N. Georgia
The B41 is on the fender tag as well, but it really doesn't make a difference. It is a St. Louis build, and the 11" brakes were probably an add on by one of the owners. It makes the choice for a disk brake conversion on the rear easier It's too bad I just spent money to rebuild one of them, it was missing the parking brake strut on the left. I'll run with these brakes until it is time, I figure the project will be done in about 10 years. Still wouldn't mind having the punch card read to get a new Broadcast Sheet made.
[Re: 268RTs4ME]
#204134
01/27/09 12:34 AM
01/27/09 12:34 AM
The galen book I have Chrysler corp.production option code book 1972-1974 says that the B25 are 10 X 2.50' RR brakes auto adjust (72-74) and the B41 reads (72)Front disc brakes drum rear.Then B41 listed again as (73-74) front disc brakes power/drum brakes The B 25 (72-74) are 10 X 2.50" rr brakes self adjust
You are correct.
I didn't realize we were talking about a 1974 models and i took my info out of the 69-71 book.
I seldom comment on anything newer than a 1971.
Sorry.
#204135
01/27/09 11:56 AM
01/27/09 11:56 AM
Iko
N. Georgia
You are correct.
Sorry.
Thanks a bunch, I'll still buy the book though Seems like a good investment.
[Re: 268RTs4ME]
#204137
01/28/09 06:16 PM
01/28/09 06:16 PM
Iko
N. Georgia
See your in N. Georgia, headed that way end of Jan to pick up 69 Coronet RT I purchase in Dahlonoga,south of Dalton.
I never realized it but it really is MOPAR country out here. Good luck in your find!
