Holley fuel injection #2040473
03/28/16 03:37 PM
03/28/16 03:37 PM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
Would a Holley 112-578 throttle body be good for a nitrous sb race motor? Is there a better option? New to fuel injection and thinking of starting to collect some parts to get the conversion started.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Holley fuel injection [Re: 1967dartgt] #2040483
03/28/16 03:48 PM
03/28/16 03:48 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Nice! Once you get the tuning figured out it will be worth it's weight in gold.
[img] [/img]
Re: Holley fuel injection [Re: 1967dartgt] #2040486
03/28/16 03:51 PM
03/28/16 03:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That is just the throttle body for a multi point..
I went with this one... its the 4150 base.. 1000cfm
http://www.summitracing.com/parts/hly-550-500
or if you want to use a 4500 base they have this one
http://www.summitracing.com/parts/hly-550-501
you still have to buy injectors and the pump... talk
to Monte for a price.. he helped me out
EDIT
also being that its a dry throttle body its just
air so its more air than the same size as a carb
thats moving both air and fuel
wave
Re: Holley fuel injection [Re: 1967dartgt] #2040518
03/28/16 04:37 PM
03/28/16 04:37 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Gonna try to technology huh old man?? laugh
Re: Holley fuel injection [Re: 1967dartgt] #2040555
03/28/16 05:42 PM
03/28/16 05:42 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Check out the MS3PRO, more features than the holley and less money.
MS3PRO.COM
I have a holley cast 4150 Throttle body, not as low profile as some of the other ones but less expensive.
68 Barracuda Formula S 340
Re: Holley fuel injection [Re: 1967dartgt] #2040886
03/29/16 01:01 AM
03/29/16 01:01 AM
Hilltown Pa
Hilltown Pa
Need a 4500 throttle body as all my intakes and nitrous plates are 4500.
Re: Holley fuel injection [Re: 1967dartgt] #2040920
03/29/16 01:52 AM
03/29/16 01:52 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
My buddy has the MS3PRO and wow, that is bang for the buck!!
Brad check out the new stuff from FItech too, good thread on the bullet about that
Re: Holley fuel injection [Re: 1967dartgt] #2041048
03/29/16 10:35 AM
03/29/16 10:35 AM
an8sec70cuda Offline
FWIW...I'm freshening up a 434" SB Chevy out of a friends boat. It had FAST XFI on it, but now he's changing over to FITech and gonna have Kevin Mullins tune it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Holley fuel injection [Re: SpareParts] #2041071
03/29/16 11:23 AM
03/29/16 11:23 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I have the FITech unit on order. $150 rebate + Summit 10% wasn't a bad deal. Should arrive next week. Evidently the Throttle body only flows ~850, which should be OK for me, but might be a deal breaker for a fast guys. Evidently they do not offer much tuning support via the advanced software, and I am a little afraid of what the interface will look like, I have yet to find anyone that has messed with it.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Holley fuel injection [Re: 1967dartgt] #2041092
03/29/16 11:57 AM
03/29/16 11:57 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Cheaper systems are great.............until you can't get any support or find any help that knows anything about them.
Several on the net rave about Mega-Squirt......YET, to see one on a fast race car. Probably a reason for that
Re: Holley fuel injection [Re: Monte_Smith] #2041102
03/29/16 12:13 PM
03/29/16 12:13 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
MS is not plug and play, nor is it something you can get into if you don't have the desire to learn and understand how the system works. Not a great choice if you're looking to plop something on and go.
Re: Holley fuel injection [Re: 1967dartgt] #2041180
03/29/16 02:18 PM
03/29/16 02:18 PM
Hilltown Pa
Hilltown Pa
Monte there is not a down side to running a 2000 cfm throttle body on a 420 cu in small block?
Re: Holley fuel injection [Re: 1967dartgt] #2041197
03/29/16 02:42 PM
03/29/16 02:42 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No.........you can NOT over "carb" an EFI engine per say. It only uses the air it needs. Makes no difference how much TOO BIG throttle body seems for requirements
Re: Holley fuel injection [Re: 1967dartgt] #2041208
03/29/16 03:05 PM
03/29/16 03:05 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have seen EFI small blocks with 4000CFM of throttle bodies on a tunnel ram
Re: Holley fuel injection [Re: 1967dartgt] #2041209
03/29/16 03:06 PM
03/29/16 03:06 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The only exception I have to what Monte says, would be light throttle driveability. I know this is a race engine, and not a big concern, but going to big on a throttlebody (and I mean way to big)can make real world driving tricky. It can be difficult to get throttle enrichments just right, and the throttle cable "cam" usually needs some mods to be able to have fine foot control.
And as far as the holley efi... I am sold on its effectiveness and capabilities. I've used MS stuff(never the 3 though) and find it hard to believe that it is more capable than the Holley.
Re: Holley fuel injection [Re: 1967dartgt] #2041260
03/29/16 04:41 PM
03/29/16 04:41 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Most throttle bodies have the option to be one to one, or progressive on the linkage. We set up all drag cars one to one......BUT, if you wanted easier drivability with a big throttle body, you could opt for progressive. I have two HUGE throttle bodies on my jet boat, on a fairly mild 500" motor. I set the linkages up progressive and throttle control is VERY good
As far as EFI, guys like what they like and what they like, tends to be better than everything else to THEM. I have tuned cars with Motec, Holley, FAST, Big Stuff, Accel, Hal-Tech, Fuel Tech, Mega-Squirt and some others. I have YET to see anything more versatile and easier to work with than Holley. Not saying that because I work for Holley either. Every racer I have talked to that switched to Holley from what they had, can't believe how easy it is to use and how much more it does than what they had before. Now Motec, is probably the most advanced system out there, but you need a PhD to be able to use it all......LOL!!!
For "power adder" controls, nothing and I repeat NOTHING is as versatile as Holley. Not even close
Re: Holley fuel injection [Re: 1967dartgt] #2041302
03/29/16 05:44 PM
03/29/16 05:44 PM
Hilltown Pa
Hilltown Pa
Thanks Monte.
