Re: speedo gear, what am I looking at?
[Re: stumpy]
#2040113
03/27/16 11:37 PM
03/27/16 11:37 PM
RapidRobert
What Stump said and there's another number on the end of the "26-3" so it is 26-32 (teeth)
[Re: Adam71Charger]
#2040389
03/28/16 01:28 PM
03/28/16 01:28 PM
Posts: 1,274 Ontario.Canada
can.al
Ontario.Canada
the tooth count is determined by your rear gears. matching the tooth count to your ring gear i.e. 32 / 3.23. 35 / 3.55 etc will usually get you close enough with a tire close to stock size...
[Re: Adam71Charger]
#2040896
03/29/16 01:13 AM
03/29/16 01:13 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
You align the markings on the die-cast part (notch to dot) for the gear you have, i.e., with your 29 tooth pinion, you'd used the 26-31 range.
Rick
[Re: Adam71Charger]
#2041383
03/29/16 08:25 PM
03/29/16 08:25 PM
Posts: 406 California City, CA
dart440
California City, CA
The housing is an eccentric, so the different "positions" move the gear closer/farther away from the speedometer drive gear on the output shaft (you rotate the housing to a different position to a mark on the tail shaft housing). This is because the gears are larger/smaller depending on the number of teeth on the gear. You want to align the corresponding mark on the housing with tail shaft housing mark for the correct number of teeth on you gear so that the gear is positioned properly to the output shaft speedometer drive gear (not too close, not too far away, just right). Put it in the wrong spot and you can damage the gear or have a non-functioning speedometer.
Chuck
When you work on Spaceships for a living, how bad can a workday be?
