b1 heads,indy block oiling issues #2040863
03/29/16 12:28 AM
03/29/16 12:28 AM
Denair,Ca
Armdropdart68 Offline OP
Denair,Ca
I have a set of original b1 heads with t&d rockers on a indy maxx aluminum block. it has the drain lines from the heads to the pan and on the stand at 2-3k rpm its starts to run out of oil. the indy block holds more in the valley area and with the lines I put extra oil in it and it still is going dry. any suggestion or info would be greatly appreciated. THANKS
Re: b1 heads,indy block oiling issues [Re: Armdropdart68] #2041156
03/29/16 01:42 PM
03/29/16 01:42 PM
No actual B1 heads/Indy block experience but is the oil psi dropping? might be a prob on the supply side somewhere (more details please) but here's a BTT for ya since you ain't gettin any love on this deal
