65 small block 727 question... #2040841
03/29/16 12:01 AM
03/29/16 12:01 AM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
. so i have a 65 D100 with a poly 318 and cable operated 727...
my question is, if i decide to drop a good running 360 into it will be a direct swap?
is the converter hub the same on a 65 as it is on the newer ones? i thought somewhere in the 60's the size changed.. if it is different is there anyway to put the newer motor up to the older trans/converter?
i'd just throw another 727 in it but i'd like to keep the dash mounted shifter...
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: 65 small block 727 question... [Re: abodyjoe] #2040848
03/29/16 12:07 AM
03/29/16 12:07 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I believe your going to want to pick up one of those balanced flex plates. Then you won't have to mess with the trans at all, other then bolting it to the motor.
I believe the converter change was between 67 & 68, so the 65 trans won't play well with a 360 converter. Gene
Re: 65 small block 727 question... [Re: abodyjoe] #2040852
03/29/16 12:10 AM
03/29/16 12:10 AM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
yea i have the flexplate..
Damn! thats what i thought.... wonder if i can convert the older trans to accept the newer converter?
Re: 65 small block 727 question... [Re: abodyjoe] #2040856
03/29/16 12:15 AM
03/29/16 12:15 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Talk to a local shop about getting a custom TC made. I had one done for a 78 400 in front of a 64 727 years ago. You can get it with the 360 imbalance weights if needed.
Don't be the exception.
Re: 65 small block 727 question... [Re: Supercuda] #2040861
03/29/16 12:24 AM
03/29/16 12:24 AM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
hmmm.. good idea.. thanks
Re: 65 small block 727 question... [Re: abodyjoe] #2040879
03/29/16 12:52 AM
03/29/16 12:52 AM
KY
65pacecar Offline
65pacecar  Offline
KY
The 65 727 uses a 19 spline converter in the big block, I think same for small block. If so, they are hard to find and pretty limited availability unless you go custom or change the shaft to the later style.
Re: 65 small block 727 question... [Re: abodyjoe] #2040965
03/29/16 03:15 AM
03/29/16 03:15 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, it's done often. You need a later input shaft and reaction shaft support. In the long run it's the best way to go, avoids having to shop for an orphan converter.
Re: 65 small block 727 question... [Re: abodyjoe] #2040991
03/29/16 08:37 AM
03/29/16 08:37 AM
Andrewh Offline
Andrewh  Offline
I don't know about a 360, but the magnum 5.9 bolted on and ran just fine.
I used the b&m flex plate, that was designed to balance instead of adding weights to the conveter.
been running it for a while now.
There was 1 hole that didn't line up and the brace on one side wouldn't bolt up either. but most people seem to leave that off anyway.
Re: 65 small block 727 question... [Re: John_Kunkel] #2040995
03/29/16 08:53 AM
03/29/16 08:53 AM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
ok cool.. o i have a few parts transmissions laying around so thats a great option..
Re: 65 small block 727 question... [Re: Andrewh] #2040996
03/29/16 08:55 AM
03/29/16 08:55 AM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
the converter hub was the same size?
i'm not worried about the balance.. i have a b&m flex plate laying around already .
Re: 65 small block 727 question... [Re: abodyjoe] #2040999
03/29/16 09:08 AM
03/29/16 09:08 AM
West Michigan, Usa.
K
killersix Offline
killersix  Offline
K
West Michigan, Usa.
The slant six is the one with the conv. hub change that you are thinking of.
Re: 65 small block 727 question... [Re: killersix] #2041021
03/29/16 10:08 AM
03/29/16 10:08 AM
Berlin, N.J.
abodyjoe Offline OP
abodyjoe  Offline OP
Berlin, N.J.
ok... so its just the spline count then?
Re: 65 small block 727 question... [Re: abodyjoe] #2041205
03/29/16 02:56 PM
03/29/16 02:56 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
If have a parts transmission you should change the input shaft assembly. That is what I am doing for a 65 BB tranny right now.
Re: 65 small block 727 question... [Re: John_Kunkel] #2041212
03/29/16 03:09 PM
03/29/16 03:09 PM
that's what I would do & then you could could use any later 727 converter & if it ain't a 360 (ext balanced) converter, you already have the B&M conversion flexplate in hand to match it to the ext balanced 360 eng.
Re: 65 small block 727 question... [Re: abodyjoe] #2041409
03/29/16 08:48 PM
03/29/16 08:48 PM
Andrewh Offline
Andrewh  Offline
I kept the 65 transmission and converter. But I might not understand what you are talking about.
it was behind a poly 318, and I just used the b&m flex plate. no issues for the last 7 or 8 years.
Re: 65 small block 727 question... [Re: Andrewh] #2041772
03/30/16 10:56 AM
03/30/16 10:56 AM
moparx Offline
moparx  Offline
the combo you are using is perfectly ok, and you can expect no problems to arise. what the benefit of changing to the later model pump parts is when you are shopping for, or need a converter that is, or has very different characteristics than your stock 1965 converter. the early [65 & earlier] converters are hard to find and much more expensive in a performance, high stall speed, design than the later converters are, hence the pump changes to take advantage of the vastly different, superior, and much cheaper converter offerings. hope this clears up the understanding of the reason to swap to later parts.
beer
Re: 65 small block 727 question... [Re: killersix] #2042147
03/30/16 06:24 PM
03/30/16 06:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
And the early 273. (pre-'68)
Re: 65 small block 727 question... [Re: abodyjoe] #2042411
03/31/16 12:37 AM
03/31/16 12:37 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The input shaft spline count changed around '66-67
I think you can install a later year input shaft in the trans and use the more common '67 and up torque converters. The 360 balance issue can be handled with the special B&M flexplate or a correctly counterbalanced torque converter. The older 360 and Magnum 360 used different counterbalance weights.
Call John Cope at Cope racing transmissions to verify compatibility.
I think (been awhile) that the 340/360 motor mount ears on the drivers side are about 1/2" further back (or forward) from the 318, and the drivers side boss for the lower engine to trans strut is forward a but requiring a spacer and longer bolt. I think on my truck I just ended up having one of the motor mounts turned sideways to make up the difference? That was back around 1980, so getting hard to remember.
