Re: how to clean a bare block
[Re: Adam71Charger]
#2040010
03/27/16 09:26 PM
03/27/16 09:26 PM
Posts: 18,157 Mass
DAYCLONA
Mass
For parts other than the block, I typically clean with laquer thinner and wire brush Lacquer thinner fine for internals, but will/can leave a residue that might affect paint adhesion on the outer block surface, I generally use acetone
[Re: DAYCLONA]
#2040033
03/27/16 10:06 PM
03/27/16 10:06 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
For parts other than the block, I typically clean with laquer thinner and wire brush Lacquer thinner fine for internals, but will/can leave a residue that might affect paint adhesion on the outer block surface, I generally use acetone I havent experienced that with laquer thinner, I use it to clean and prep about every surface (car parts) I paint. I switched to laquer thinner years ago when i figured out mineral spirits left oily residue, and brake cleaner also left a residue. Ill have to look closely next time Im cleaning to paint, for the residue.
[Re: can.al]
#2040195
03/28/16 01:09 AM
03/28/16 01:09 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Hopefully you guys are wearing rubber gloves and the appropriate respirators, with laquer thinner, acetone, muratic acid etc.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: can.al]
#2040993
03/29/16 08:40 AM
03/29/16 08:40 AM
Posts: 2,658 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Evaporust will get the rust off but a drum to submerge it in is $1,000 and it doesn't remove grease or paint. Burn and tumble won't clean out the oil galleys or get the rust out of the water jackets. Hot tank is the only real choice.
2011 Drag Pak Challenger
[Re: can.al]
#2041055
03/29/16 10:47 AM
03/29/16 10:47 AM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Hot tank is the only real choice. Not really !! Hot tank is "old school". The caustic chemicals remove "most" paint and "most" grease and oil but because there s little motion in the tank, it can only attack what it soaks into and relies on the manual rinse to remove the sludge its managed to penetrate. Oil galleys need major attention afterwards. Hot tank chemicals DO NOT remove rust. Any bearings left in the motor will be eaten by the caustic. The hot solvent washers will remove paint and grease and oil very effectively because the block is getting a constant flow - removing the crud with the flow of the solvent. But oil galleys still need major attention. The solvents are safe on bearings. The bake process turns paint oil and grease to ash. But again, does nothing for rust. The shot process does a great job on rust BUT only where it can come in direct contact, so water jackets still don't get touched. Shot will peen every machined surface so its advisable to leave all bearings and main caps in the block so those surfaces don't get damaged. The lifter bores will need adjusting afterwards and the block will need to be decked. Regardless, a very good cleaning with hot soap and water is required after all machining then a thorough spray of WD40 to prevent rust. Once you've done assembly to a point you want to paint, wash off the WD40 with brake cleaner. After brake cleaner I wash the motor down with oil and grease remover in a paint gun. Pay attention to the small pores in the surface. You want to make sure they're dry before painting. On my blocks I remove every bit of casting flash both inside and out before I send the motor out for cleaning.
[Re: Adam71Charger]
#2041061
03/29/16 10:57 AM
03/29/16 10:57 AM
Adobedude
New Mexico
Does shorts and flip flops count? As long as they are steel toe.
