Page 4 of 7 1 2 3 4 5 6 7
Re: 318 for drag race use [Re: WO23Coronet] #2039737
03/27/16 02:46 PM
03/27/16 02:46 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
qwkmopardan what did your 587 heads flow?
273 at .525" lift
205 at .300" lift
Re: 318 for drag race use [Re: qwkmopardan] #2039743
03/27/16 02:59 PM
03/27/16 02:59 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Originally Posted By qwkmopardan
It did start drinking water after the second pass yesterday. Engine is old and I sonic tested the cyl walls a couple winters ago and they were on the thin side, but a lot of cash was already spent so he had to use it. Just used his car as an example of capabilities of eddy RPM heads. Only flowed around 275 IIRC. Those heads on a 318 would feed it very well and only a high 10 second goal, easy. $6000 budget would get him an engine to do what he is looking for.
was there any fill in the block Dan? we pushed our old 340 block close to those numbers before a rod let go (150 passes), but it was concrete above the core plugs and aftermarket 2 bolt steel caps. Do you think sleaves would help or hinder a project of this magnitude?
Re: 318 for drag race use [Re: J_BODY] #2039769
03/27/16 03:28 PM
03/27/16 03:28 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Yes the 64 Dart's block is filled with HardBlock. I have never had fill in my junk. My 418 was never even sonic tested. I must of got lucky and got a thick one. My faster 367 developed a radial crack just below the deck. I sonic tested and the wall is .159 just under the crack. cyl #6 bottom, major thrust.
Re: 318 for drag race use [Re: 318 racer] #2039782
03/27/16 03:42 PM
03/27/16 03:42 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Originally Posted By 318 racer
First post here..
I'd like to build a 318 for drag race use. Max 8000 rpm.Would like to know what you guys would use for all parts for the build. However there are 2 items the engine must use...
Edelbrock cylinder heads
ThermoQuad carburetor.
No it's not a NHRA/IHRA engine for class racing,but would like to build along those parameters.
Cam,intake header size,crank,rods pistons,oiling system etc... what would you use?
Engine will be in a A-body Duster.
These naysayers are ridiculous. You need about 540 horse to reach your goal, you already have Ed heads, get them ported by someone good, they will go over 300 cfm at .700 lift when done properly, this will support over 600 horse. Being small displacement it will need some rpm so build it with that in mind. Honda rod journals with rods atleast 6.300 long, good light pistons, 13+ compression, paired shaft 1.7 ratio rockers, spend time to get the geometry perfect, ported super victor intake, custom solid roller with good PR oiling lifters. Have the carb done by a superstock carb builder, and youll be there.
Re: 318 for drag race use [Re: 318 racer] #2039813
03/27/16 04:32 PM
03/27/16 04:32 PM
Az
Crizila Offline
Crizila  Offline
Az
You might want to look at Hughes Engines re; those heads. They sell a fully ported version that "they" claim flow 299cfm @ I believe .700. You also might look at the larger ( big block version ) of the TQ. I believe it is rated at 1100 cfm. They are identical on the outside. Just larger primary's.
Fastest 300
Re: 318 for drag race use [Re: Crizila] #2039847
03/27/16 05:13 PM
03/27/16 05:13 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
The claimed flow is even higher then that. 305 @ .700 or the big mouth version at 319.9 @ .700.
Flow ratings of their 3 port sizes are here: http://www.hughesengines.com/TechArticles/1headflowchartscomparisons.php#SBLARPM
Re: 318 for drag race use [Re: qwkmopardan] #2039861
03/27/16 05:30 PM
03/27/16 05:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
"my friends 64 Dart"..... thinking that's the one that just split a bore in a block I was reading about
so you are saying you can make a stock stoke 318 run 10.70s in his 3200lb car for $6K?
Re: 318 for drag race use [Re: Quicktree] #2039872
03/27/16 05:51 PM
03/27/16 05:51 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
He already owns the heads, otherwise it would cost more.
Re: 318 for drag race use [Re: qwkmopardan] #2039889
03/27/16 06:14 PM
03/27/16 06:14 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I missed it by a little. If he assembles it himself about $6300
Grind crank $200
Pistons and rings $750
Scat rods $350
Main and rod bearings $125
Balance assembly $300
Bore and hone w tq-plate $275
Square deck block $175
Align hone block $300
Hot tank and crack check block $125
Cam bearings and freeze plugs, installed $125
Restrictor tubes and oiling mods. $200
Timing chain set $100
Cam and lifters $325
Porting, valve job and springs $1000
Victor 340 intake $300
Hughes rocker arm kit $500
Port intake $225
Smith Bros pushrods $175
Cometic head gaskets $175
M72 oil pump $45
Moroso oil pan and pick-up tube $300
Other gaskets $100 oil pan, intake, rear seal, timing cover, etc.
ARP main cap bolts $50
ARP head bolts $85
Did I miss anything?
Re: 318 for drag race use [Re: qwkmopardan] #2039892
03/27/16 06:20 PM
03/27/16 06:20 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
For another grand it could have a new steel 4" crank and be 396 c.i. and run a half second quicker.
At that level it probably would break the stock main caps within a couple hundred passes.
Re: 318 for drag race use [Re: qwkmopardan] #2039897
03/27/16 06:26 PM
03/27/16 06:26 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
LOL. I only have 7500 dollars in my whole 422 build including my R3 block and Indy heads. I love reading about guys wanting to do things the HARD and expensive way just to end up paying more to go slower.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 318 for drag race use [Re: 318 racer] #2039901
03/27/16 06:31 PM
03/27/16 06:31 PM
Georgia
3
318 racer Offline OP
Georgia
I can assemble the engine,no problem. The machine work,not sure on the cost,that I'll have to discuss with the shop. They are very good at what they do.
Some parts I have,most I do not. The Edelbrock heads that I got on a fire sale are the 60767 heads which are bare heads,but they are the NHRA legal replacement heads for the 318.I never looked at them until today.
Even if the car ran 10.90's I'd be very happy.
Re: 318 for drag race use [Re: 318 racer] #2039904
03/27/16 06:38 PM
03/27/16 06:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
So you need porting, valves, springs retainers, locks and
rockers... thats a fair amount of money in itself.. and
thats not even going with Ti valves
wave
Re: 318 for drag race use [Re: qwkmopardan] #2039968
03/27/16 08:20 PM
03/27/16 08:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Grind crank $200
Scat rods $350
Port intake $225
M72 oil pump $45
ARP head bolts $85
good luck with that, the RPM'S will kill those hughes rockers in a minute. the cam and springs it will take to get there will probably be a lot more than you quoted. sorry i just don't see it. be interesting to see this happen. you could save the class racers a lot of money if you could make it happen.
Re: 318 for drag race use [Re: Quicktree] #2040018
03/27/16 09:34 PM
03/27/16 09:34 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
OP, as someone who has also spent a lot of time and money on an oddball combo just to be different my hat is off to you. punkrocka
It's fun to go fast with a motor others look down their noses at, and to have people come look at it and tell you stories. BUT all that never put a dime in my pocket and eventually I got tired of trying to push a large rock uphill.
Good luck with your quest for the 10:70's.
Re: 318 for drag race use [Re: pittsburghracer] #2040083
03/27/16 11:10 PM
03/27/16 11:10 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Sure there's an easier way to skin a cat.... (no reference to Hemi, just a saying... hope he understands smile ) it's just the OP wants a 318. Most of us agree there's a lot of approaches to use different combos to run harder, for less coin, but the challenge is there. If he follows through, I hope to hear some results.
Re: 318 for drag race use [Re: 318 racer] #2040103
03/27/16 11:23 PM
03/27/16 11:23 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Forget about IMO, It seems your on a budget also. It can be done, yes. But not for the reasons you are considering. Your in for a big let down. Don't waste your time brother. up
Re: 318 for drag race use [Re: 318 racer] #2040119
03/27/16 11:49 PM
03/27/16 11:49 PM
Georgia
3
Georgia
As I've said before,I really do appreciate the posts...It's WHY I asked all of you for your insight!
Trust me,I've been looking for info,that's why I came here.
If I go thru with it,I will post a detailed build,and let you guys know how it worked out.As of now,I think I'm still going to build it.
Re: 318 for drag race use [Re: Quicktree] #2040258
03/28/16 03:38 AM
03/28/16 03:38 AM
408Dust Offline
408Dust  Offline
Originally Posted By Quicktree
[quote=qwkmopardan]I missed it by a little. If he assembles it himself about $6300
Grind crank $200
Scat rods $350
Port intake $225
M72 oil pump $45
ARP head bolts $85
That's for sure guess Parson&Meyers, Tillburg and others have been over charging people for class motors LOL
Re: 318 for drag race use [Re: pittsburghracer] #2040272
03/28/16 06:15 AM
03/28/16 06:15 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Doing things the hard and expensive way? You mean... like building a Mopar ANYTHING instead ov a Chevy? Hahahahahaha. So you'd rather run a Mopar. Why? you could go faster with a Chevy for less...??? I mean... if its ALL about money right...???
Way back at the street races, easily one ov the coolest cars there was a ratty Maverick with a 289. Not a 302, not a 351 (like everyone else was running), no stroker... just a lil tiny V8 with a stroke that barely shows up on microscope. That was a damn fast car. The only reason it wasn't faster was because buddy was piss-poor broke and had a weird way ov doing things. He'd rev that lil turd to the moon on weekends and daily drive it 40 miles to work and back the other 5 days a week. He said there was an easy 70HP left in that engine, and by the junk he used and the compromises (very first gen Edelbrock heads, CR in the 8's, and a REALLY crappy exhaust) he made, i do not doubt it. That car could have easily been 200lbs lighter too. Some people LOVE the revs...
I'm personally watching this thread, as i've decided to (probably) build a 318 Magnum for my car. If there was a 340 Magnum i'd build that, but there isn't, and no reasonable way to build one, and i like more about the 318 than the 360. I too want a lot ov power, and have an embarrassing budget... but i'm a tricky guy. I know there's a way. I wanna explore the Edelbrock Magnum heads though... for a more efficient engine (Mustang mods and import N/A ratios have all but killed 'old school' for me), unless there is an even more modern design out there that doesn't cost much more. I'm 'only' looking for 450ish HP though... heh heh...
