Question on electronic gauges #203948
01/25/09 12:22 PM
01/25/09 12:22 PM
Hannibal Missouri
71dart Offline OP
3 yrs. for 500 posts
71dart  Offline OP
Hannibal Missouri
Can you run multiple electronic gauges from one sending unit? Like run to electric water temperature gauges from the same electronic sending unit?
Thanks for the info.
Mike
Re: Question on electronic gauges [Re: 71dart] #203949
01/25/09 12:53 PM
01/25/09 12:53 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
aftermarket gauge wont work with the stock sending unit.
Re: Question on electronic gauges [Re: 05dakota] #203950
01/25/09 01:02 PM
01/25/09 01:02 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I think you would get some back feed/back grounding issues with 2 gauges grounding out through the same resistor ground...but, then again...maybe not?
you might only read half the value of actual...if you send 2 12V signals through 1 resistor...I dunno....hook it up and try it!
**Photobucket sucks**
Re: Question on electronic gauges [Re: 71dart] #203951
01/25/09 06:41 PM
01/25/09 06:41 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I run my water temp gauge and my electric fan controller from the same sender.
