J/Y Electric fan upgrade #2037274
03/23/16 05:20 PM
03/23/16 05:20 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Didn't know if I should put this in this section since its not necessarily a question but I just did the install of the twin electric fan upgrade with one piece shroud from a Ford Contour V6 in my '71 Satellite. If you had doubts about it effectiveness, don't.
I picked it up a couple of years ago to take care of my air flow cooling problem with a lesser quality electric fan. You know, cool at speed, runs hot idling. It is almost drop in. It fits perfectly in place on the radiator and all I had to do is drill four holes in the tabs that are used for the fans factory mounting. I also drilled and tapped 4 holes in the radiator "frame" where you mount the stock Mopar shroud. I'm using the 26" Champion aluminum radiator which practically bolted right into the stock location and is touted as allowing the stock shroud to bolt right up. So I would think this would work with the factory radiator as well. I did place a spacer (exhaust manifold washer) behind the plastic mounting tabs so it didn't break when tightened as there was a small space between the mounting location and the tab. And I used a washer under the bolt to spread out the clamping force.
I already had a relay in place for the previous fans so I tied right into that. They have a 20 amp fuse on each fan to handle the initial turn on of the fans and it's handing it just fine. I did not try to wire in the high/low speed control/sensor which looks to just be a thermostat of some sort so they only operate on high. I still can't hear them over the rumble of the 408 and Flowmasters though :-) . This thing moves some serious air. Almost couldn't pull the paper of the a/c condenser that I was using to test the suction. I adjusted the activation temp to where the car just idled for about 30 mins and stayed right at 190 degrees. I actually had to adjust it up because it was making the car run too cool.
So all of this was a really long winded path to say it works and if you were were on the fence about it, DO IT!
I didn't think to take any pics unail it was complete.
I'll see if I can post one.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: J/Y Electric fan upgrade [Re: roe] #2037309
03/23/16 06:20 PM
03/23/16 06:20 PM
Tacoma, Washington USA
Adam71Charger Offline
Thank you for information. I will most likely using the champion 26" too, how many rows is yours?
Re: J/Y Electric fan upgrade [Re: roe] #2037621
03/24/16 02:45 AM
03/24/16 02:45 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I run that fan on my Jeep with a stroker motor, I went with the spal PWM controller and I like it. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: J/Y Electric fan upgrade [Re: Adam71Charger] #2037625
03/24/16 03:03 AM
03/24/16 03:03 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Mine is a 3 row. Will try to remember to post a pic tomorrow
Re: J/Y Electric fan upgrade [Re: roe] #2038051
03/24/16 09:23 PM
03/24/16 09:23 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I've had one of these in my car for about 3 years now.
FYI: The factory contour wiring uses a 60A maxi fuse to power both fans and a 70A relay.
The little resistor pack deal is for the low speed. The low speed has always been more than enough to keep my car cool. You basically turn the power going into that resistor/diode on and you get low. The factory does this by having the computer ground the low relay to turn low on and the high to turn high on. I used the dakota digital controller to mimic this.
This is the write-up I did.
https://www.dropbox.com/s/wdvxqfd1tnhcpy3/Electric%20Fan%2026in%20Radiator.pdf?dl=0
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: J/Y Electric fan upgrade [Re: roe] #2038052
03/24/16 09:23 PM
03/24/16 09:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
$100 new from rock auto
Dimensions for fitment purposes
Don't be the exception.
Re: J/Y Electric fan upgrade [Re: roe] #2038192
03/25/16 12:52 AM
03/25/16 12:52 AM
BDW Online content
BDW  Online Content
It sounds like the fan needs at least 20A constantly when running?
What kind of alternator you running?
Re: J/Y Electric fan upgrade [Re: goldduster318] #2038275
03/25/16 04:28 AM
03/25/16 04:28 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Goldduster318 thanks for posting that. Now that I think about it I believe you posted that a couple of years ago and that is what led me to plan this install. Wiring is not my forte and I'm actually surprised I installed my relay correctly, haha. I'm gonna stick with only the high speed setup. I can't remember what size relay I used so I'll relook that part and I will bump up my fuse size to each fan. I'll try to match the factory and use a 30 amp fuse per fan and a 70 amp relay.
Here's mine:
Re: J/Y Electric fan upgrade [Re: BDW] #2038277
03/25/16 04:32 AM
03/25/16 04:32 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I'm running a magnum based motor so I'm using an alternator that can handle the output. I wouldn't be able to if I were still running the one I had before this motor. I would've upgraded to one of the aftermarket bolt ins, or the one of the Denson units.
Re: J/Y Electric fan upgrade [Re: roe] #2038374
03/25/16 11:33 AM
03/25/16 11:33 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I run a similar fan set-up in my drag car. Twin fans out of a late model Mopar. It runs a relay for each fan with the feed for the relay coming directly from the alternator output stud. Then the relays are driven by a dual position low amperage switch, left fan/off/both.They pull 28 amps running as a pair. It'll cool down in 90 degreed weather between rounds in less than 3 minutes. They move some big air, and pull some big amperage.
Doug
Re: J/Y Electric fan upgrade [Re: roe] #2039047
03/26/16 10:31 AM
03/26/16 10:31 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How do the electric fans do with the a/c? Have you wired them to come on automatically when the a/c engages or do you not get much cooling at low speeds unless the fans kick in?
Re: J/Y Electric fan upgrade [Re: DaytonaTurbo] #2039111
03/26/16 12:35 PM
03/26/16 12:35 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I don't have a/c right now but still plan to add it in new the future. Golduster318 may. Maybe he'll chime in. I could see adding in another relay that is triggered by the he a/c.
Re: J/Y Electric fan upgrade [Re: roe] #2039408
03/26/16 11:27 PM
03/26/16 11:27 PM
Lake Orion, MI
Lake Orion, MI
I don't have A/C, but the dakota digital controller has a way to wire it where it will trigger the High fan speed with the A/C. I have this feature connected to a toggle switch, because originally, I thought I might need to be able to cool the motor off fast, but even the low works really well.
I drove in the Woodward Dream Cruise traffic and never even needed the high speed...and it was 87 degrees outside.
Re: J/Y Electric fan upgrade [Re: roe] #2039542
03/27/16 08:19 AM
03/27/16 08:19 AM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
I thought about a conversion but I am to worried about having much current at the bulkhead.
Re: J/Y Electric fan upgrade [Re: magiccuda] #2039545
03/27/16 08:57 AM
03/27/16 08:57 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you do not know why that is not an issue you should not mess with it at all.
Re: J/Y Electric fan upgrade [Re: magiccuda] #2039714
03/27/16 02:11 PM
03/27/16 02:11 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Just wire it up with a relay that pulls all the power directly off the alternator. The power to run it never goes through the bulkhead. The relay is wired to supply power with ignition in the run position. Since you only need a small trigger wire to supply power to the relay which turns it's on in the run position there is no extra draw through the cars original wiring. And I also ran a bypass wire so the amp guage won't see the power either. Says dead center and never shows charge or discharge so I installed a voltmeter.
Re: J/Y Electric fan upgrade [Re: roe] #2039979
03/27/16 08:43 PM
03/27/16 08:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Exactly. All the loads should be wired on the alternator side of the ammeter feed. The ONLY current going thru the alternator should be to or from the battery and the battery only, NOTHING else.
Re: J/Y Electric fan upgrade [Re: roe] #2039991
03/27/16 09:00 PM
03/27/16 09:00 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I had the contour fan setup on my champion 4-core and it was OK, but with the A/C condenser I could not get good airflow. I replaced the 4-core radiator with a Griffen 2-core with 1.25" cores the radiator is a but thinner so I think airflow through the radiator should be better. I also am trying two 13" SPAL cooling fans. This was changes I made this winter so I won't know how well they work for a few months.
Re: J/Y Electric fan upgrade [Re: 451Mopar] #2040008
03/27/16 09:25 PM
03/27/16 09:25 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I'm really surprised you say this. Mine is a 3 row champion 26" and though I don't have the a/c installed I still have the condenser in place. I figured it would be a good shield to protect my radiator fins from damage. Mine was moving serious air through both.
Re: J/Y Electric fan upgrade [Re: roe] #2040513
03/28/16 04:33 PM
03/28/16 04:33 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Mine was OK until I was using the A/C on a 95+ degree day. The 4-Core radiator is pretty thick and even though the Contour fans are pretty thin, they were close to the water pump pulley, maybe less than 1" (440 engine.)
I think the 3-Core you have may cool better because of better airflow through it.
My cooling issues were just with the A/C on and even at highway speeds, that is why I am thinking the airflow through the core may be the issue.
