Steering Link Torque Question #2039378
03/26/16 10:41 PM
03/26/16 10:41 PM
Brea, Ca
Dart Racer Offline OP
Brea, Ca
Anybody have the torque spec for the castle nuts that hold the steering link and ball joint links on a 62 Dart manual steering? I looked high and low on the internet and no luck on a 62.
Time to go racing!
Re: Steering Link Torque Question [Re: Dart Racer] #2039581
03/27/16 10:45 AM
03/27/16 10:45 AM
moparx Offline
moparx  Offline
should be the same as a 62 plymouth B body. according to my FSM that is 40ft-lbs [max] for the idler arm and steering gear [pitman] arm stud to center link, and 40ft-lbs [max] for the tie rod ends to center link and lower ball joint/steering arm. upper ball joint studs to spindle are 100ft-lbs. the lower ball joint to lower control arm are 100ft-lbs also. the lower bolts holding the steering link [lower ball joint] to the spindle is 120ft-lbs.
beer
Re: Steering Link Torque Question [Re: moparx] #2040241
03/28/16 02:40 AM
03/28/16 02:40 AM
Brea, Ca
Brea, Ca
THANKS!!!!!!!!!!!!!!
Re: Steering Link Torque Question [Re: Dart Racer] #2040309
03/28/16 10:20 AM
03/28/16 10:20 AM
moparx Offline
moparx  Offline
i just love 62 darts ! up i always said i would like to own one some day, but that isn't likely, since i got to finish my 33 dodge humpback panel truck first, and get my charger back out & see what damage the red squirrel did to the dash wiring. i need another 3/4 of a life time at least.......
beer
