4 link kit, good price? Will it work for my 37?
#2038995
03/26/16 03:32 AM
03/26/16 03:32 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
http://www.ebay.com/itm/1938-Plymouth-Deluxe-Rear-Suspension-4-Link-Kit-watts-link-crossmember-fast-usa-/182014593434?hash=item2a60ea499a:g:0sUAAOSwL7VWtR-P&vxp=mtr
Not sure if this uses air bags or coil overs?
Input is appreciated
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: 4 link kit, good price? Will it work for my 37?
[Re: AZ_A12_BEE]
#2039091
03/26/16 12:10 PM
03/26/16 12:10 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Your link works, I looked at it, the compatibility chart shows it fits 22 vehicles, all Tri 5 Chevrolets.
The link to the installation instructions comes up with nothing available.
The pictures in the listing do not show a typical triangulated 4 link like GM or Ford have used for decades. More like a splayed foot 4 link.
The listing is too skiffy for me to consider it, I get an itch between my shoulder blades reading it.
It does say, at the very top of the listing "Upgrade Today! Coil Overs Not Included, Save $$$!!"
[Re: Supercuda]
#2039544
03/27/16 08:53 AM
03/27/16 08:53 AM
Posts: 19,396 north of coder
moparx
i couldn't find anything using that link, but the "johny law motors" set up i mentioned listed a 38 plymouth as one application as well as a ton of tri-5 chevys and almost all a,b & e body mopars as well, using the same picture to describe the same basic kit. i didn't notice about the coilovers not included. with that being said, what is the difference between a "triangulated " and a "splayed" 4 bar setup ? i thought those were one and the same ?
[Re: moparx]
#2039552
03/27/16 09:13 AM
03/27/16 09:13 AM
Supercuda
About to go away
About to go away
up yours
The SPECIFIC kit the OP linked to on Ebay is listed as "1938 Plymouth Deluxe Rear Suspension 4-Link Kit watts link crossmember fast usa". The application chart ONLY shows tri5 fitment, NOTHING else. The JLM website shows a vehicle specific 4 link kit that matches identically to the Ebay listing the OP is asking about in all regards EXCEPT the claim to fit a 1938 Plymouth. Can't it be made to work? Much like my wife with a lot of hassle I am sure it will. Is that why the OP was looking for a "fits a 1938 Plymouth" 4 link kit? I seriously doubt it. See the axle mount location then the frame mount location of both the upper and lower arms. Johnny Law Motors: Essentially a parallel 4 link with the front mounts wider than the rear. A real triangulated 4 link: Note how the second pic shows the bars actually making a TRIANGLE? Not so with the first pic.
[Re: Supercuda]
#2039564
03/27/16 09:45 AM
03/27/16 09:45 AM
moparx
yes, you are correct. i just glossed over the pic and the add. when i saw [paid attention to really; my mistake ! ] the actual installed pic, it isn't a triangulated setup. i am very familiar with those used in fords and gm cars of the era[s]. it just occurred to me if i was going to go to any effort to re-do his leaf suspension, i would seriously consider a "truck arm" setup ! very easy to install, handles good, set ride height to what ever you want, and can be a cheap, almost fool proof installation. with a little thought and measurement[s], if a guy had even a tiny bit of fabrication experience under his belt, he could round up the necessary components and build it from scratch, saving some money in the process. of course, welding experience of the non "booger gum" variety would be essential. do you get your wife to help out at times ? i thought that was funny ! just yankin' yer chain - no disrespect intended !
