904 Direct clutch pack clearances
#203758
01/25/09 10:55 AM
01/25/09 10:55 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I am installing A999 parts in my tranny and just assembled the 5 disk direct clutch. Spec calls for .075-.152 pack clearance and I am getting .090" with the thinnest (.060") selective ring.
Is more clearance beneficial to reduce drag in 1st and 2nd?? I suppose I could slip a thin forward disk in place of the thicker direct disk and gain about .025".
My direct pack measures .040" which I think is fine.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 904 Direct clutch pack clearances
[Re: CJK440]
#203759
01/25/09 11:21 AM
01/25/09 11:21 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I think it's less of a drag thing and more of an engagement timing thing. With more springs working against the piston, I don't think less clearance is a big deal. But if you are running 9 or ten springs on the piston, that would be too tight. I'm sure others can correct me if I'm mistaken.
[Re: CJK440]
#203761
01/25/09 03:13 PM
01/25/09 03:13 PM
dartman366
Mt. Vernon, Ohio
That figure's to be a .018 clearance per clutch which isn't bad, but if you can tighten it up a little with a thicker snap ring that would be even better, I have set mine up as tight as .065, but mine see's strip duty only, .040 on the direct clutch will be good, and smart move on the multi spring retainer.
[Re: CJK440]
#203762
01/25/09 07:18 PM
01/25/09 07:18 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
to answer that , YES .
[Re: JohnRR]
#203764
01/25/09 08:08 PM
01/25/09 08:08 PM
Posts: 296 CT
turbocolt2.4L
CT
about .030-.040 for the forwards but i would set the direct to .060 or as close as you could get them direct it the drum the band rides on and forward is the drum with shaft.also set the front band to 1 1/4 turn from snug with a 4.2 lever and rear band to 1.75-2 turns.
[Re: turbocolt2.4L]
#203765
01/26/09 10:33 AM
01/26/09 10:33 AM
CJK440
Ansonia, CT
I could definately get the direct pack tighter with a thicker ring but I was worried it was on the low side to begin with.
I previously ran 5 A&A thins in a 4 clutch drum and clearance was very close to the low limit and I think I had some 2-3 overlap issues. Perhaps running what I have now with a little more clearance would do fine.
[Re: CJK440]
#203766
01/26/09 11:29 AM
01/26/09 11:29 AM
JohnRR
U.S.S.A.
[Re: CJK440]
#203767
01/26/09 07:09 PM
01/26/09 07:09 PM
dartman366
Mt. Vernon, Ohio
you can help the overlap by a band adjustment, to a point,,,but you should be in pretty good shape where you are at now.
