Re: dwell reading?
[Re: Ply72rr]
#2037358
03/23/16 07:45 PM
03/23/16 07:45 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Mike, I've had dwell meters with three leads, and others with two. I suspect the reason is a tachometer function as well as dwell readings. It's been a while so had to think on this one.
As has been said already, a two wire setup hooks as described. My 3 wire caught both sides of the coil plus a ground.
I have to admit I've never tried adjusting dwell by just cranking the engine over. On rare occasions I've slightly elongated the adjustment slot with a rat tail file to obtain more travel. In any case I've always made the readings with the engine running. I'd be interested in other opinions on this.
Lead, follow or get the hell out of the way
Re: dwell reading?
[Re: scratchnfotraction]
#2037418
03/23/16 09:32 PM
03/23/16 09:32 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I like 27-28° of dwell and use a performance coil. As was said - you can file the hole larger if you need more. You also want to make sure you're using the truangular shaped screwdriver point to adjust them and not just prying on the upright part of the set of points.
Re: dwell reading?
#2037457
03/23/16 10:28 PM
03/23/16 10:28 PM
Posts: 15,487 Florida
scratchnfotraction
ok. thanks. that is just the info I needed. been running pertronix points conversion so long I forgets how to troubleshoot points.
red test lead to - side of coil
black test lead to good ground
no, I did not know closing the gap increases dwell. seems I went the wrong way and it got better.
could be why I am at 25* with a wide gap?
I set points with a feeler gauge at .016 and ran it. now checking with a meter I am a little fused as in why I open the gap wide and it seemed to get better throttle response.
I will retest and see what I got now I am less fused.
Re: dwell reading?
[Re: 71GTX471]
#2037459
03/23/16 10:31 PM
03/23/16 10:31 PM
RapidRobert
As said: red to coil neg primary. gap/dwell/point life are inversely proportional. You can set the gap pretty much anywhere you want it (.017 is a good ballpark) just keeping in mind that longer dwell time/smaller gap give more power and shorter point life over time (good for high perf) as you'd be changing em out sooner as needed. For max power set the gap at .005 & if it will start then that will give you the most (as said) coil saturation time for the most power and the shortest point life over time cuz with the points touching/current flowing there is more time for them to burn (over time/wont happen overnight) & if it wont start at .005 go up in .003" deg increments till it will start. For Grandmas' DD you'd want the largest gap for the least dwell time (I'd start at .017 & maybe go up to .020"}. Perf point sets are as you know higher quality & likely have more spring tension for bounce resistance at higher RPM's
Re: dwell reading?
#2037617
03/24/16 02:28 AM
03/24/16 02:28 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
[/quote]
When you open the point gap you are advancing the timing unless you reset the timing after opening the point gap. But when you open the gap the points open sooner and it fires the coil sooner which advances the timing and gave you better throttle response. General rule of thumb was point gap about 16 to 18 and dwell about 27 to 30 for single points. Get it in them setting and it will be fine. Course dual points will have more dwell as thats the reason for dual points for more coil saturation time and stronger spark. Ron
Re: dwell reading?
#2037708
03/24/16 11:59 AM
03/24/16 11:59 AM
RapidRobert
then one day I am rolling hard and it stops running, no start = no fire = the pad/tip on points burnt right off the arm.
I will pick up a new set of points and retune. the metal contact tip not the fiber piece that rides on the shaft cam lobe correct? that is pretty rare, I'd suspect an oil film on the point contact faces or a very high draw coil or a cheap set of point or maybe it it is a good set then one that came thru with bad metallurgy (Murphys law) plus alot of dwell gives more burn time but rarely burns off the tip!. You are lightly lubing the cam lobes for the fiber piece?
