Page 1 of 6 1 2 3 4 5 6
78 Utiline Build #2036947
03/23/16 02:27 AM
03/23/16 02:27 AM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Been working on my 78 Utiline recently. Just want to get or running and driving so I can enjoy it. I've had it for about a year now. Got it for a song and they even trailered it to my house (1 hr drive one way!). Has a 225 w/ a 3 on the tree. Eventually I will build a 505 for it (78 440 is sitting in the corner of my garage waiting) that is about 600hp/600ftlb on pump gas (or I may consider E85) and an auto.
Found some old slots and lowered it this past weekend. I'm digging the stance! Here are some pics.
-78 Utiline (5.7 Hemi)
Re: 78 Utiline Build [Re: MoPwer] #2036953
03/23/16 02:58 AM
03/23/16 02:58 AM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Engine seemed to have a miss. Checked compression and #3 was at about 30psi while the rest were 120. Pulled the head, looked fine, no burnt valves and gasket was good. The top thrust side of a few of the pistons were eroded a little on the edge (maybe had water in them at some point?). Pulled the pistons and all of the top rings were broken in half! #3 was in about 6 pieces and the second ring was busted. Ordered replacement pistons, rings and rod bearings and did a frame in "rebuild" just so I can drive it for a while. Back together and running better but one of the rocker adjusters was loose. I need to tighten it up before I start driving it regularly. May try a jam nut or peening the outside to tighten it back up. It does have a Super Six intake that someone installed at some point.
Re: 78 Utiline Build [Re: MoPwer] #2036956
03/23/16 03:02 AM
03/23/16 03:02 AM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Here is the future engine holding the floor down right now.
Re: 78 Utiline Build [Re: MoPwer] #2036984
03/23/16 08:10 AM
03/23/16 08:10 AM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
Nice truck, looks great lowered. Getting close to setting my 505 in.
Re: 78 Utiline Build [Re: MoPwer] #2037054
03/23/16 11:51 AM
03/23/16 11:51 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
good lookin old truck
1981 Dodge D150 360 auto
Re: 78 Utiline Build [Re: MoPwer] #2038395
03/25/16 12:00 PM
03/25/16 12:00 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Sweet!
Re: 78 Utiline Build [Re: MoPwer] #2040281
03/28/16 08:28 AM
03/28/16 08:28 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Sweet! up
I'll eventually find another '72-'80 truck (in decent shape, I hope) when I have the time to work on it and room for it. A Utiline would be nice. grin
Here's an old pic of my '78 PW I bought new-
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 78 Utiline Build [Re: I_bleed_MOPAR] #2043881
04/01/16 09:06 PM
04/01/16 09:06 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Originally Posted By I_bleed_MOPAR
Sweet! up
Nice! I've got an old 73 PW rock crawler I finished last year.
Re: 78 Utiline Build [Re: MoPwer] #2045717
04/03/16 09:56 PM
04/03/16 09:56 PM
Buford, GA
Buford, GA
Nice job. up
Tim
'71 Charger 383/727
Re: 78 Utiline Build [Re: MoPwer] #2067081
05/04/16 12:03 PM
05/04/16 12:03 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Couldn't wait. After working on my buddies 454 for last few weeks, I NEED to drop the 440 into the 78 Utiline! That slant 6 ain't cutting it for torque. Scored 3 items recently to get me there: Dana 60 FF that I'll cut down and convert to a SF, low miles 727 Trans with the torque converter, and an auto column.
Re: 78 Utiline Build [Re: MoPwer] #2067083
05/04/16 12:06 PM
05/04/16 12:06 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Debating on going straight to ladder bars when I do the 60. I really would like to keep them on the outside of the frame and use the front spring mount for the bars. I'll have to build my own but any thoughts on this? The reason for wanting to do it this way is so I can keep my stock fuel tank.
Re: 78 Utiline Build [Re: MoPwer] #2067375
05/04/16 07:57 PM
05/04/16 07:57 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Maybe I should just keep it simple and tune some leaf springs and Caltracs.
Re: 78 Utiline Build [Re: MoPwer] #2067647
05/05/16 10:32 AM
05/05/16 10:32 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The leaf springs and Caltracs will work fine and save time AND money, cool build! up
JB Rhinehart, Realist
A-Body's RULE!
Re: 78 Utiline Build [Re: Rhinodart] #2067680
05/05/16 12:09 PM
05/05/16 12:09 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Thanks. That does seem to be the more sensible option.
Re: 78 Utiline Build [Re: MoPwer] #2067729
05/05/16 01:31 PM
05/05/16 01:31 PM
Chattanooga, TN
KDY Offline
KDY  Offline
Chattanooga, TN
Great looking truck! I'm glad to see more people building trucks.
I went with a '69 mustang gas tank - check out posts #1220272 and #1220292 on this link: https://board.moparts.org/ubbthreads/ubbt...tml#Post1220262
I'm using stock leafs on mine. Leaf technology has come a long way over the years. People are going 1.10 60ft on them so a set of Caltracs or Assassins should do the trick.
Re: 78 Utiline Build [Re: KDY] #2068353
05/06/16 03:42 PM
05/06/16 03:42 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Did you remove some leaves? I seem to recall mine having more.
Re: 78 Utiline Build [Re: MoPwer] #2068366
05/06/16 04:17 PM
05/06/16 04:17 PM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
Nice project keep the updates coming
Re: 78 Utiline Build [Re: 68dodge] #2068410
05/06/16 05:52 PM
05/06/16 05:52 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Any other pics of your roll bar? Looks pretty tidy.
Re: 78 Utiline Build [Re: MoPwer] #2068509
05/06/16 10:15 PM
05/06/16 10:15 PM
Chattanooga, TN
KDY Offline
KDY  Offline
Chattanooga, TN
No. I actually added an extra main leaf.
Re: 78 Utiline Build [Re: MoPwer] #2074028
05/15/16 07:25 PM
05/15/16 07:25 PM
Phoenix, AZ
MoPwer Offline OP
MoPwer  Offline OP
Phoenix, AZ
Made some rooms for the BB. Sold the engine and Trans.
440 is on the stand ready to be cleaned up and regasketed.
