What is the difference between the Drag Pak & Hellcat? #2035861
03/21/16 05:24 PM
03/21/16 05:24 PM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
I see one is called the Drag Pak and sports one kind of supercharger, and the Hellcat looks way different....Cubic inches aside, what is the difference?
Re: What is the difference between the Drag Pak & Hellcat? [Re: Dragula] #2035883
03/21/16 06:09 PM
03/21/16 06:09 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Lol, dragpak is a factory built car intended for strip use only, doesn't get a vin, similar to the 68 barracuda/dart.
Hellcat is a wicked modern muscle car
Re: What is the difference between the Drag Pak & Hellcat? [Re: Dragula] #2035914
03/21/16 07:22 PM
03/21/16 07:22 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
DP has a 2.9 Whipple blower which is a class rule in fs/xx.
Mopar to the bone!!!
Re: What is the difference between the Drag Pak & Hellcat? [Re: GTS340] #2035951
03/21/16 08:11 PM
03/21/16 08:11 PM
I should have been more specific. Just the difference in the blown engines...
Looks like two different supercharger top ends between them...The DP engine says Whipple right on it, but the Hellcat engine looks a bit different.
Can I buy either supercharger setup, and build my own long block?
Re: What is the difference between the Drag Pak & Hellcat? [Re: Dragula] #2035959
03/21/16 08:23 PM
03/21/16 08:23 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
The DP is based of the 5.7 but which one? Early or VVT?
Matt
Re: What is the difference between the Drag Pak & Hellcat? [Re: Dragula] #2036030
03/21/16 09:52 PM
03/21/16 09:52 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Have not found a Hellcat IHI blower for sale yet, the Hellcat setup is built with 100K mile durability in mind. The DP setup is built with light weight and rules compliance in mind. Here is a breakdown of the Hellcat specs:
http://www.hotrod.com/features/1503-inside-the-hellcat-hemi-v8/
DP specs I have not found any as far as long block.
Re: What is the difference between the Drag Pak & Hellcat? [Re: 72Swinger] #2036130
03/21/16 11:59 PM
03/21/16 11:59 PM
Read thru some of that and the Hellcat blower is 2.4L according to them and the DP is a 2.9L unit....Do we know if the DP unit is intercooled? I suspect not, but figured I would ask.
Re: What is the difference between the Drag Pak & Hellcat? [Re: Dragula] #2036358
03/22/16 11:51 AM
03/22/16 11:51 AM
Ohio
blown71duster Offline
Ohio
Re: What is the difference between the Drag Pak & Hellcat? [Re: Dragula] #2036449
03/22/16 01:53 PM
03/22/16 01:53 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
you can buy everything for a hellcat here
http://www.factorymoparparts.net/auto-pa...components-scat
Re: What is the difference between the Drag Pak & Hellcat? [Re: Dragula] #2036450
03/22/16 01:55 PM
03/22/16 01:55 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Re: What is the difference between the Drag Pak & Hellcat? [Re: blown71duster] #2036591
03/22/16 05:15 PM
03/22/16 05:15 PM
Originally Posted By blown71duster
You know, I called those guys over x-mass I think and they didn't have a bracket that fit one like that! That is way easier to do, I would just need an engine plate sandwiched in there.....
I have a 5.7 core down at the shop...I would just need the stroker kit, oil pan, engine plate and super charger and carb....
Thanks for posting that.
Re: What is the difference between the Drag Pak & Hellcat? [Re: Dragula] #2036722
03/22/16 08:27 PM
03/22/16 08:27 PM
Ohio
Ohio
There is a place selling procharger pattern brackets made for fabbing . I have seen guys use wood as a pattern to figure out how they want to mount the supercharger , then transfer that to the real bracket:
http://www.ebay.com/itm/ProCharger-Universal-Supercharger-Mounting-Bracket-F1-F2-/111614966845
http://www.ramforum.com/f44/taking_procharger_making_better-78993/
