Re: Drilled Reaction Shaft Support in 727 Trans
[Re: SlickRS23]
#2035218
03/20/16 06:45 PM
03/20/16 06:45 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The purpose of enlarging the hole is to provide additional lube to the front clutches. 9/64" (.140") is pretty large, I normally drill them .094" for the street. (the original hole is tiny)
Since this hole is a wide open pressure leak from the converter pressure circuit it would seem to be counterintuitive but the converter pressure is regulated to below line pressure so it's not that big of a pressure loss.
[Re: SlickRS23]
#2035823
03/21/16 04:33 PM
03/21/16 04:33 PM
John_Kunkel
Rio Linda, CA
The way the 727 is designed, the front drum and the released clutches spin the opposite direction from the input shaft by .80 in 1st gear....IOW, the actual surface speed of the drum and clutches is 180% of input shaft speed in the opposite direction; this causes a lot of parasitic loss from the drag of the released clutches, thus the increase in fluid to lube them.
The idea of increasing the orifice size to send more lube to the front clutches sounds good until you realize that the extra fluid has nowhere to go, it just deadheads in the front drum. That's why I like to drill the outer periphery of the drum to give the fluid an escape path.
[Re: SlickRS23]
#2035831
03/21/16 04:47 PM
03/21/16 04:47 PM
Posts: 145 Chicagoland 'Burbs
SlickRS23
Chicagoland 'Burbs
Thanks John Kunkel. I see you have spent a little time inside a 727. I think I might be over thinking this. So, it should probably be OK to use this shaft as is? My concern is that I would be taking oil away from the converter as this car will probably never see any racing. Thanks, Jeff
By the way, This trans I'm working on is a restoration project of an original six barrel car, Thanks again
[Re: SlickRS23]
#2035841
03/21/16 05:01 PM
03/21/16 05:01 PM
John_Kunkel
Rio Linda, CA
As I stated earlier, the converter has its own separate pressure regulator valve which regulates the converter pressure well below line pressure. If the trans is healthy, any excess leakage in the converter/lube circuit will be compensated by allowing more flow into the converter circuit.
I'd run it.
[Re: SlickRS23]
#2035902
03/21/16 06:52 PM
03/21/16 06:52 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
If you are that concerned why not just replace the shaft, it's not like it has a VIN stamped in it ...
[Re: wedgg440]
#2035952
03/21/16 08:11 PM
03/21/16 08:11 PM
John_Kunkel
Rio Linda, CA
Does anyone have a picture of this holes location in the reaction support?Is it both in the early and 1971 up support? Pic below shows the hole's location, this one is enlarged. The lube hole was discontinued in '74. John,what size are the bleed holes in the direct drum in your photo, and how many are there? Any info would be appreciated! The holes are 3/16" 12 holes total in 3 staggered rows.
