Re: 68 b-body window slides
[Re: car48nut]
#2035146
03/20/16 04:27 PM
03/20/16 04:27 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
can the plastic window slides still be bought from chrysler, I know they were expensive. Dixie has them and they're way less
[Re: car48nut]
#2035197
03/20/16 06:23 PM
03/20/16 06:23 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I've found them for under 50 a side online for original mopar parts... dodge trucks I believe up to the early 90s used the same piece. They also repop them now I think.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: car48nut]
#2035373
03/20/16 10:29 PM
03/20/16 10:29 PM
Posts: 306 Georgia
69bfan
Georgia
The mylar pieces are still available and they retail at close to $73 each from Chrysler. Be very careful in purchasing the cheaper ones on the market as people are passing them off as being original Chrysler pieces. Personally, unless the items are not in the sealed wrap from Chrysler, I would not trust them to being the real deal. The manufacture of the reproductions has redone the tooling and they are much more correct as the first run was too thick and stiff. You can use the reproductions, but make sure that they are of the recent run and be very careful as they are not quite as user friendly as the OEM pieces. Your car is a post car, so these pieces are also used on the rear pop out quarter windows aw well. I stock both styles, so I always point the differences out to my customers.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: car48nut]
#2035458
03/21/16 12:07 AM
03/21/16 12:07 AM
Posts: 306 Georgia
69bfan
Georgia
I sent you a private message, let me know if you have any questions.
[Re: car48nut]
#2036090
03/21/16 11:13 PM
03/21/16 11:13 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
can the plastic window slides still be bought from chrysler, I know they were expensive. If the parts in this pic are what you want, here are the Chrysler part numbers. #2932230 is the weatherstrip including the plastic slides/clips. Slide/clip alone is #4198752. You can check your local dealer or an online dealer for price and availability. As already mentioned, they are also available from reproduction dealers. I have not used Chrysler or reproduction ones myself, so cannot comment on either.
