Holley HP modification for timed vacuum port? #2035467
03/21/16 12:22 AM
03/21/16 12:22 AM
Fort Collins, Colorado
CoDart Offline OP
CoDart  Offline OP
Hi everyone, I just got a 850cfm Holley HP carb for my 440. I was wondering if there is a way to make the carb have timed vacuum advanced as there is not one single port on the carb? Or should I lock the timing out? What im running is a stock low compression 440 with a HP cam.
Thanks in advanced!
Re: Holley HP modification for timed vacuum port? [Re: CoDart] #2035470
03/21/16 12:24 AM
03/21/16 12:24 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You can take it off the metering block if you know where to look and what to do.
Re: Holley HP modification for timed vacuum port? [Re: CoDart] #2035684
03/21/16 01:08 PM
03/21/16 01:08 PM
AndyF Offline
AndyF  Offline
You can buy a new base plate with a timed vacuum port. They aren't super expensive.
Re: Holley HP modification for timed vacuum port? [Re: CoDart] #2035740
03/21/16 02:17 PM
03/21/16 02:17 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
What do you have the initial and total timing adjusted to now without the vacuum advance? I always use manifold vacuum with great success.
