best sealer for fuel tank sender?? #2033103
03/17/16 01:28 PM
03/17/16 01:28 PM
mn
flyman Offline OP
flyman  Offline OP
mn
Iam looking for the best sealant to use to seal the fuel gauge sender unit on my 1957 truck? Thanks moparts!!
Re: best sealer for fuel tank sender?? [Re: flyman] #2033156
03/17/16 02:42 PM
03/17/16 02:42 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Rubber gasket. Find one or make one.
Re: best sealer for fuel tank sender?? [Re: DaytonaTurbo] #2033167
03/17/16 02:56 PM
03/17/16 02:56 PM
mn
flyman Offline OP
flyman  Offline OP
mn
Wont the ethenol in todays fuels eat at the rubber?
Re: best sealer for fuel tank sender?? [Re: flyman] #2033194
03/17/16 03:33 PM
03/17/16 03:33 PM
dogdays Offline
dogdays  Offline
It didn't hurt the gasket in my '64Dog.
Use a material that is resistant to ethanol and gasoline when you cut your gasket.
R.
Re: best sealer for fuel tank sender?? [Re: flyman] #2033650
03/18/16 10:39 AM
03/18/16 10:39 AM
Manitoba, Canada
Manitoba, Canada
Not with the proper rubber.
Re: best sealer for fuel tank sender?? [Re: DaytonaTurbo] #2034103
03/18/16 10:10 PM
03/18/16 10:10 PM
IN
ahy Offline
ahy  Offline
IN
Is the sender bolt in? Or ring clamp style like the later cars?
Either way I would buy or make a gasket. Sealant and gas do not get along well and hard to get a durable seal w/o gasket. Good clamp on a gasket is the best with a thin coat of aviation sealer if the sealing surfaces are a bit rough.
Re: best sealer for fuel tank sender?? [Re: ahy] #2034949
03/20/16 11:30 AM
03/20/16 11:30 AM
mn
flyman Offline OP
flyman  Offline OP
mn
thanks for the replies. It is the old school type ring clamp.
Re: best sealer for fuel tank sender?? [Re: flyman] #2035442
03/20/16 11:42 PM
03/20/16 11:42 PM
IN
ahy Offline
ahy  Offline
IN
The gasket for a 60's/70's car type sending unit is available if yours is the same.
http://www.manciniracing.com/magastase.html
