having trans problem in my duster
#203506
01/24/09 11:40 PM
01/24/09 11:40 PM
Posts: 111 oregon
DJC_GT
super street
super street
oregon
My duster has a a999 out of a 85 dodge pu that has worked great for awhile until last weekend the converter hub broke. Had the converter fixed, removed front pump and cleaned it, installed new gasket, o-ring, bushing and seal.
Just fired it up, nothing! wont go into gear. Also the drive line will not rotate, its like the trans is stuck in park.
Did i knock something loose when i was removing the front pump? going to drop the pan tomm. Thanks in advance, daniel
67 dart gt 440,727 pro street
67 dart gt 273, 904 90k miles
73 duster 318 904 3;55's
74 dart sport, tired 318
74 power wagon, dirt bike hauler
Re: having trans problem in my duster
[Re: PC-CHARGER]
#203508
01/25/09 12:15 AM
01/25/09 12:15 AM
Posts: 111 oregon
DJC_GT
super street
super street
oregon
hi, thanks for your reply, the pump looked great. I had to stake the new bushing in and that was the main reason to pull the pump. I got lucky and the piece that broke off the converter hub was large. Does the trans have to be upright when you pull the pump? I had the trans on the bench when i used a slide hammer to pulled the pump.
[Re: PC-CHARGER]
#203510
01/25/09 12:27 AM
01/25/09 12:27 AM
Posts: 111 oregon
DJC_GT
super street
super street
oregon
ok, will do a pressure check. What is making me think there is issue with the linkage inside the trans is that when you disconnect the driveline from the rearend and place the trans in neutral and try and turn the driveline it doesnt move, feeld like it is in park.
[Re: DJC_GT]
#203512
01/25/09 12:34 AM
01/25/09 12:34 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
if you removed the front pump..
after re-assembling the trans did you see if you could turn the input shaft by hand??
if one of the clutch packs moved foward, and was not reset or checked to make sure everything was engaged properly...the trans is binding...
also..you have to make sure the converter engages correctly into the pump...
it is alot easier to get everything to fall into place if the trans is on its end..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: PC-CHARGER]
#203513
01/25/09 12:54 AM
01/25/09 12:54 AM
Posts: 111 oregon
DJC_GT
super street
super street
oregon
PC_Charger-left the valvebody in, shift lever moves with linkage removed, poured over a qt in the converter prior it fitting it, 3 qts or so in trans before i fired it up, dipstick shows full running in neutral
