cuda shock plates...will it fit??
#203473
01/24/09 11:08 PM
01/24/09 11:08 PM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i have a 70 gran coupe was a 318 car and has what i think is a 8 1/4 rear(deff not a 8 3/4) i have been building a 8 3/4 out of a 69 road runner to put a lil bigger tire under the gran coupe what i need to know is ...will the shock plates maybe even the u bolts from the 8 1/4 fit the 8 3/4 or will i have to track some down(the road runner rear didnt have them) and if i do have to track them down what other cars (a,b,c body) would also work? thanks guys
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: cuda shock plates...will it fit??
[Re: toplescuda]
#203475
01/24/09 11:41 PM
01/24/09 11:41 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
Yeah they fit, the only time you have to change is when you have a 7.25. If you are unsure of what rear you have the 7.25 has 2.5" tubes, the 8.25 & 8.75 both have 3" tubes.
[Re: MoparJoe]
#203479
01/25/09 03:26 AM
01/25/09 03:26 AM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
The #'s stamped into the plates you need are 1856346 & 1856347. Practically all B,C, & E's from early '60's to early '70's with 8 3/4, 8 1/4, & Dana 60 used 'em. Also A body with 8 1/4 & 8 3/4. I think the AAR & T/A E bodies used different.
