Page 4 of 8 1 2 3 4 5 6 7 8
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #2033730
03/18/16 12:53 PM
03/18/16 12:53 PM
NB, Canada
Mirada 80 Offline
Mirada 80  Offline
NB, Canada
Great thread, looks good, I am looking at doing the same to my '55 Chrysler Windsor.
Keep your Mopar all Mopar
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #2037089
03/23/16 12:40 PM
03/23/16 12:40 PM
Caldwell, Idaho
67R/T4speeder Offline OP
Caldwell, Idaho
Waiting on this kit http://www.engine-swaps.com/Pages/ProductsYear/87.96Dakota.html
Wondering if I need there oil pan too HMMMMMM
They say LA will sit in same location as a Magnum but would rather wait and mock up with it to be sure before welding frames together. Just want to be sure on angle of block and firewall clearance.
Since I had a Magnum block and V6 spool stock mounts were still in place I mocked up with bell housing and all looks good.
Thanks Mirada
Plazakota [Re: 67R/T4speeder] #2037099
03/23/16 12:46 PM
03/23/16 12:46 PM
Caldwell, Idaho
Caldwell, Idaho
Holding the broom up for now smile
I am pulling rear axle out of Dakota while waiting to see if I can use that on Plazakota also
Plazakota [Re: 67R/T4speeder] #2038614
03/25/16 05:59 PM
03/25/16 05:59 PM
Caldwell, Idaho
Caldwell, Idaho
I was happy the body mounts bolt is not rotted away and didn't break off. New bushing from Andy B. fit real nice too.
Re: Plazakota [Re: 67R/T4speeder] #2047009
04/05/16 12:23 PM
04/05/16 12:23 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
looks good - I put a front clip from a 79 magnum on mine in the late 90's but the project got side tracked.
Re: `56 Plazakota [Re: 67R/T4speeder] #2047826
04/06/16 11:55 AM
04/06/16 11:55 AM
Caldwell, Idaho
Caldwell, Idaho
Thanks Cuda,
I got the metal around body mounts straight now, no rust just beat up and bushings in place. Even the special body mounts bolts are still solid, that was a relief.
Now I need to do the biggie and get these two chunks of metal welded together.
Re: `56 Plazakota [Re: 67R/T4speeder] #2048653
04/07/16 09:39 AM
04/07/16 09:39 AM
moparx Offline
moparx  Offline
nice job on the body mounts ! up
beer
Re: `56 Plazakota [Re: 67R/T4speeder] #2049938
04/08/16 07:33 PM
04/08/16 07:33 PM
Peoples Republic of Oregon
W
wayfarer Offline
wayfarer  Offline
W
Awesome project! Keep us posted.
www.qualityengineeredcomponents.com
Early Hemi Parts and Tech
EarlyHemi and flat 6&8 trans adapters
***inventory clearance in progress. Nothing held back. See website.***
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #2051096
04/10/16 03:35 PM
04/10/16 03:35 PM
Caldwell, Idaho
Caldwell, Idaho
I couldn't take it any longer I had to find out what critters have done to the inside of this heater box. I was surprised to only find some leaves boogie
Now I can test heater core and reseal this part up.
Sure like getting to all this while just standing where engine goes, super easy to do now.
Re: Plazakota [Re: 67R/T4speeder] #2055532
04/16/16 01:49 PM
04/16/16 01:49 PM
Caldwell, Idaho
Caldwell, Idaho
Heater core passed the test so cleaned everything up, fixed heater doors and resealed box and put it back on. The blower motor makes noise so I ordered a new one and will paint that mounting plate then.
Was going to mount brake booster of Dakota but hard to tell where engine will sit so better wait.
Now all the hard to get to things are finished I feel better about welding frame in place now.
Re: `56 Dodge modern front end swap advice [Re: John_Kunkel] #2055569
04/16/16 03:13 PM
04/16/16 03:13 PM
Caldwell, Idaho
Caldwell, Idaho
Originally Posted By John_Kunkel
The rear end in my '56 is from a '65-'67 B-body (59 1/2" overall width), perches moved inboard to 41" centers.
Do you have a engine compartment pic you can share ?
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #2055588
04/16/16 03:46 PM
04/16/16 03:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a couple.
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #2055609
04/16/16 04:26 PM
04/16/16 04:26 PM
Caldwell, Idaho
Caldwell, Idaho
Thank you John
Re: `56 Plazakota [Re: 67R/T4speeder] #2062199
04/26/16 07:27 PM
04/26/16 07:27 PM
Caldwell, Idaho
Caldwell, Idaho
Getting closer to the weld-a-thon, but not lined up yet though. Inching it closer and closer tell it is right on, over lapping the two frames where I can to make a stronger weld.
Re: `56 Dodge modern front end swap advice [Re: 67R/T4speeder] #2063551
04/28/16 07:30 PM
04/28/16 07:30 PM
Caldwell, Idaho
Caldwell, Idaho
I got my wheel base to match original so time to take apart again and clean some metal, then put together and close those gaps. I left them open since it is easier to get apart since it fits very tight together. Then drill those holes out I have marked to plug weld.
Drop spindles are on the way since I like how Johns car sits.
Re: `56 Plazakota [Re: 67R/T4speeder] #2063924
04/29/16 12:14 PM
04/29/16 12:14 PM
Caldwell, Idaho
Caldwell, Idaho
Spindles arrived
Re: `56 Plazakota [Re: 67R/T4speeder] #2068451
05/06/16 07:03 PM
05/06/16 07:03 PM
Caldwell, Idaho
Caldwell, Idaho
Double checking caster to help make sure frame angle is correct.
Re: `56 Plazakota [Re: 67R/T4speeder] #2068607
05/07/16 12:19 AM
05/07/16 12:19 AM
Cambridge Idaho
RUMBLON Offline
RUMBLON  Offline
Cambridge Idaho
GREAT PROJECT!!!!!! Nice job. I have a 92 Dakota I just bought with a 318 magnum in that runs like a top. Its going into something. I have a 50 shortbed satudebaker truck but I also have a 35 plymouth 2 dr sedan and this 56 DODGE. I bought it as I knew where a damaged 2 door was that I thought I WAS GETTING. No deal so here it sits.
I love 56s and the Dodge has a ton of chrome. Im looking for a 2 door project.
RUMBLON
Re: `56 Plazakota [Re: 67R/T4speeder] #2068843
05/07/16 02:07 PM
05/07/16 02:07 PM
Caldwell, Idaho
Caldwell, Idaho
Good looking cars for sure, and I love Studies, my buddy has one I put a Camaro sub frame in about 15 years ago he loves it.
Re: `56 Plazakota [Re: 67R/T4speeder] #2069221
05/08/16 10:31 AM
05/08/16 10:31 AM
Between Houston & Galveston TX
SattyNoCar Online work
SattyNoCar  Online Work
Originally Posted By 67R/T4speeder
Spindles arrived
What brand are those?
John
