brake conversion #2032726
03/16/16 10:59 PM
03/16/16 10:59 PM
louisiana
72pettyblue Offline OP
louisiana
I converted my 72 charger from 4 wheel manual drums to power front disc/rear drums. I changed everything from booster/master cylinder to calipers/wheel cylinders and all lines and hoses. Everything works but the brake pedal does not come up to the same height and the brake light switch is not even close to making contact with pedal. Is there something else I need to change? Or is there a different switch I can use to make up the difference?
Re: brake conversion [Re: 72pettyblue] #2032746
03/16/16 11:24 PM
03/16/16 11:24 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
The pedal typically sits a lot lower with a power brake car. You'd need to adjust the brake switch since you had manual before.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: brake conversion [Re: 72pettyblue] #2032831
03/17/16 12:54 AM
03/17/16 12:54 AM
louisiana
louisiana
no adjustment on the old switch, there is an adjustable one available. I just wanted to make sure before I purchased one. Thanks
Re: brake conversion [Re: 72pettyblue] #2032835
03/17/16 01:00 AM
03/17/16 01:00 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The switch bracket may be adjustable.
Re: brake conversion [Re: 72pettyblue] #2033365
03/17/16 08:37 PM
03/17/16 08:37 PM
Andrewh Offline
Andrewh  Offline
I cut a piece of metal to make a bracket that fit around the pedal to make up the distance.
