Dana for Handling/Protouring?
#2032231
03/16/16 10:24 AM
03/16/16 10:24 AM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Is there any reason other than the extra weight (big reason I know...) and limited gear ratios not to run a Dana vs 8.75 on a pro-touring type build? I am looking at the Strange S60. http://www.strangeengineering.net/high-p...ing-mounts.htmlI completely went through the 8.75 in my Challenger, moser axles, Detroit trutrac, ect... and by the time your done, there isn't a huge price difference in just going Dana and picking up some strength to boot and all new bolt in and forget it parts. I'd want to do it all ready to roll, with a brake kit if anyone has any recommendations on that front as well, I plan on running gen 3 Viper disks in the front. This will be for my Charger big block, 4-speed, XV level 1 suspension. Thanks for the help!
Re: Dana for Handling/Protouring?
[Re: Jerry]
#2032268
03/16/16 11:25 AM
03/16/16 11:25 AM
challenger70
Berwyn, IL
you don't need the holding capacity of the dana. the dana was used in drag racing because of slicks. you could probably stick a 7 1/4 in there for the turns and you'd be fine.
cons -
cost weight ratios not easy to switch gears less availability of parts I know I am just thinking if I am going to dump 2k into redoing an 8.75 I minds well spend 3 and have a brand new bulletproof Dana with disks brakes, powdercoated, ready to rock n' roll. I am on the list for the Passon 5 speed, so i think that with 3.54's in the Dana would be a nice livable on the street choice. This car will be 95% messing around on the street and occasional open track day type deal. I also like the idea of being able to throw slicks/drag radials on it and doing drag racing too. It would be 1 less thing to worry about down the road if I add big power too.
[Re: challenger70]
#2032357
03/16/16 01:33 PM
03/16/16 01:33 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I have already broken a side gear in the Spicer clutch diff in my 8 3/4. All it is is peppy 6.1 and a 6spd in my 72 Dart. The S60 housings are lighter than factory 60 housings. Im thinking a Dana is in my future with the big Ford ends for the big non adjustable bearing. Cornering is harder on stuff than you think. After this year I hope to find a buyer for my 8 3/4.
Mopar to the bone!!!
[Re: 72Swinger]
#2032405
03/16/16 02:46 PM
03/16/16 02:46 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I have already broken a side gear in the Spicer clutch diff in my 8 3/4. All it is is peppy 6.1 and a 6spd in my 72 Dart. The S60 housings are lighter than factory 60 housings. Im thinking a Dana is in my future with the big Ford ends for the big non adjustable bearing. Cornering is harder on stuff than you think. After this year I hope to find a buyer for my 8 3/4. Are those new side gears or old factory original ones?
A new iron curtain drawn across the 49th parallel
[Re: challenger70]
#2032459
03/16/16 04:18 PM
03/16/16 04:18 PM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
cons -
cost weight ratios not easy to switch gears less availability of parts I know I am just thinking if I am going to dump 2k into redoing an 8.75 I minds well spend 3 and have a brand new bulletproof Dana with disks brakes, powdercoated, ready to rock n' roll. I am on the list for the Passon 5 speed, so i think that with 3.54's in the Dana would be a nice livable on the street choice. This car will be 95% messing around on the street and occasional open track day type deal. I also like the idea of being able to throw slicks/drag radials on it and doing drag racing too. It would be 1 less thing to worry about down the road if I add big power too. I have to agree with Jerry. My 742- 8¾" has been through a lot in the last 6 years with no failures. 3.23 gears and stock axles pushing almost 600HP. Now I have only had drag radials on the car once and it mostly track driven. There is a lot to making these last, oils, axle play, etc. I have a grand total of $350 into mine......
[Re: 67autocross]
#2032498
03/16/16 05:19 PM
03/16/16 05:19 PM
72Swinger
Nebraska
I have already broken a side gear in the Spicer clutch diff in my 8 3/4. All it is is peppy 6.1 and a 6spd in my 72 Dart. The S60 housings are lighter than factory 60 housings. Im thinking a Dana is in my future with the big Ford ends for the big non adjustable bearing. Cornering is harder on stuff than you think. After this year I hope to find a buyer for my 8 3/4. Are those new side gears or old factory original ones? Broken originals, I got it used and it had a broken cross shaft but the gears looked good so I put in a new cross and new clutches. Now it has all new guts with the same fresh clutches. I am hard on her, I can do a real good Dick Landy impression minus the cigar. I am pretty sure it would grenade if it ever dead hooks. Car weighs 3700 with driver.
[Re: 72Swinger]
#2032547
03/16/16 06:35 PM
03/16/16 06:35 PM
67autocross
Manitoba Canada
I have already broken a side gear in the Spicer clutch diff in my 8 3/4. All it is is peppy 6.1 and a 6spd in my 72 Dart. The S60 housings are lighter than factory 60 housings. Im thinking a Dana is in my future with the big Ford ends for the big non adjustable bearing. Cornering is harder on stuff than you think. After this year I hope to find a buyer for my 8 3/4. Are those new side gears or old factory original ones? Broken originals, I got it used and it had a broken cross shaft but the gears looked good so I put in a new cross and new clutches. Now it has all new guts with the same fresh clutches. I am hard on her, I can do a real good Dick Landy impression minus the cigar. I am pretty sure it would grenade if it ever dead hooks. Car weighs 3700 with driver. Thanks , seems to be a bit of problem lately with some 8 3/4's wrecking side gears, the ones that I know of happened in new centre sections.
[Re: Viol8r]
#2032550
03/16/16 06:36 PM
03/16/16 06:36 PM
67autocross
Manitoba Canada
cons -
cost weight ratios not easy to switch gears less availability of parts I know I am just thinking if I am going to dump 2k into redoing an 8.75 I minds well spend 3 and have a brand new bulletproof Dana with disks brakes, powdercoated, ready to rock n' roll. I am on the list for the Passon 5 speed, so i think that with 3.54's in the Dana would be a nice livable on the street choice. This car will be 95% messing around on the street and occasional open track day type deal. I also like the idea of being able to throw slicks/drag radials on it and doing drag racing too. It would be 1 less thing to worry about down the road if I add big power too. I have to agree with Jerry. My 742- 8¾" has been through a lot in the last 6 years with no failures. 3.23 gears and stock axles pushing almost 600HP. Now I have only had drag radials on the car once and it mostly track driven. There is a lot to making these last, oils, axle play, etc. I have a grand total of $350 into mine...... Good to see you posting again Viol8r, how is the front end that you are testing working out?
[Re: 67autocross]
#2032554
03/16/16 06:39 PM
03/16/16 06:39 PM
72Swinger
Nebraska
Luckily that side gear and the one tooth off a pinion gear was all that was hurt.
[Re: challenger70]
#2032578
03/16/16 07:01 PM
03/16/16 07:01 PM
72Swinger
Nebraska
With strength comes weight, I doubt you would notice any difference from a handling perspective.
[Re: challenger70]
#2032609
03/16/16 07:41 PM
03/16/16 07:41 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I would just get a junkyard 60, have Dutchman narrow it and provide shafts, use the torino ends, explorer brake kit from a jeep place, find a set of true Spicer 3.54 gears, diff of your choice (prefer power lok) and put it together, should cost about $1200 plus your labor. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2032716
03/16/16 10:44 PM
03/16/16 10:44 PM
72Swinger
Nebraska
I would just get a junkyard 60, have Dutchman narrow it and provide shafts, use the torino ends, explorer brake kit from a jeep place, find a set of true Spicer 3.54 gears, diff of your choice (prefer power lok) and put it together, should cost about $1200 plus your labor. Tim I have considered this to, have one in the backyard, but those truck axles have 3/8" wall tube, or thicker, and after you buy ends $100, pay to have them put on $2-250, have it cleaned and painted $40? An S60 housing with billet side adjusters and choice of ends at $665 is pretty attractive.
[Re: challenger70]
#2032744
03/16/16 11:21 PM
03/16/16 11:21 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I would do either a Torino bearing 9" or a 9" floating axle before a Dana for weight. The Dana is just a heavy beast and not really necessary.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: challenger70]
#2032804
03/17/16 12:25 AM
03/17/16 12:25 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I don't know why people seem to think a 9" is a good thing. Stock, they are weak. Spend a ton of money replacing all the stock parts and you still have an axle that is just as heavy as the Dana but not quite as strong. Car Craft is a comparison between the 9", the S60 and the 12 bolt http://www.hotrod.com/how-to/transmission-drivetrain/ccrp-0806-chevy-chevelle-rear-axle-swap/
