Early A518 Transmission Upgrades Needed During Rebuild? #2032012
03/15/16 11:58 PM
03/15/16 11:58 PM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
Finally found a non lock up 518 to go in my Challenger. Came out of a 91 church van. It is at a shop now being torn down and inspected for hard part damage.
Next step will be all the clearance work to the tail of the case to fit in the E-body.
When I get to the point of having it rebuilt. What updates do these transmissions need to live in a street car. Currently it will go behind a warmed over 360, probably next year a mild stroker built for low rpm torque.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Early A518 Transmission Upgrades Needed During Rebuild? [Re: Michael Ecks] #2032017
03/16/16 12:03 AM
03/16/16 12:03 AM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
It is basically a 727 with an overdrive unit mounted in the tail-shaft. Pretty stout unit for what you are doing.
Karma has no menu. You get served what you deserve.
Re: Early A518 Transmission Upgrades Needed During Rebuild? [Re: Michael Ecks] #2032349
03/16/16 01:19 PM
03/16/16 01:19 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Early A518's had a lot of overdrive unit failures due to not enough lube/cooling oil flow through the intermediate shaft. O/D unit would overheat, cook the fluid, then cook the trans. While the shafts holes can be drilled to improve flow, it's a drill bit-eater, due to the shafts being induction hardened. Most shops will simply install the upgraded intermediate shaft with larger lube holes.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Early A518 Transmission Upgrades Needed During Rebuild? [Re: Evil Spirit] #2032493
03/16/16 05:10 PM
03/16/16 05:10 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I will store that bit of info under 518 upgrades. I recently scored a JW Ultrabell for a BB and while my racer is a BB, I was going to hang it on the front of the race built 727. After talking to a few local racers, I realize that it is overkill for my situation in the race car, but I could use it in the tow vehicle to mate a big block to a 518 and slide that into the '87 D100 when I fit it with the Dana 60-2 that will lower the final drive to 4.10 from 3.21. A lot cheaper than a Gear Vendors OD setup.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Early A518 Transmission Upgrades Needed During Rebuild? [Re: Michael Ecks] #2032497
03/16/16 05:15 PM
03/16/16 05:15 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
There are basically stock replacement ones with larger holes all the way up to billet units for the pumped up 1000+ H/P diesel crowd, and are priced accordingly. Sharp rebuilders, like John Kunkel, can probably tell you when they fixed the issue and what year the stock ones came with larger holes. Also, the O/D clutch drums interchange between the A518 based O/D units, with different amounts of clutch discs. In other words, there are stock drums that have higher torque capacities that may be able to be fitted into your O/D unit.
