wildwood brakes on a 69 dodge dart #203169
01/24/09 06:43 PM
01/24/09 06:43 PM
Cincinnati Oh
fasthawk6 Offline OP
Cincinnati Oh
i need to know how much the wildwood brakes change the offset of the wheel towards the outside of the car.
Re: wildwood brakes on a 69 dodge dart [Re: fasthawk6] #203170
01/24/09 07:42 PM
01/24/09 07:42 PM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
I went from the small drum brakes to Wilwoods on mine, and I honestly don't think it changed the offset at all. If it is changed, it's only a very small amount.
Re: wildwood brakes on a 69 dodge dart [Re: bill_greenwood] #203171
01/24/09 07:52 PM
01/24/09 07:52 PM
Cincinnati Oh
Cincinnati Oh
i had the 10" drum on mine.just finished the wilwoods today & it looks like they may be at least a 1/2" out farther.
Re: wildwood brakes on a 69 dodge dart [Re: fasthawk6] #203172
01/25/09 12:55 AM
01/25/09 12:55 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I did the same swap,I think mine might be 1/4-1/2" wider,I didn't measure but it did move the tires out very slightly.The difference in stopping power negates that IMHO.
Nautilus Racing-
Re: wildwood brakes on a 69 dodge dart [Re: Chris2581] #203173
01/25/09 02:43 AM
01/25/09 02:43 AM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Wilwood usually moves the tires out 1/4"-1/2". Aerospace moves the tires in 1/4". Car looks good and you should definitely notice a difference in stopping power.
Re: wildwood brakes on a 69 dodge dart [Re: Lil Demon] #203174
01/25/09 09:37 AM
01/25/09 09:37 AM
Cincinnati Oh
Cincinnati Oh
thanks for the info guys .i was looking at the aerospace but i did not see a kit made for the 10" drum front.
Re: wildwood brakes on a 69 dodge dart [Re: fasthawk6] #203175
01/25/09 10:50 AM
01/25/09 10:50 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't recall mine moving but I also don't recall paying attention LOL. I was running a taller wider front tire back then and it didn't cause any trouble.
68 Barracuda Formula S 340
Re: wildwood brakes on a 69 dodge dart [Re: Bad340fish] #203176
01/25/09 10:52 AM
01/25/09 10:52 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Pics of the brakes please.
Re: wildwood brakes on a 69 dodge dart [Re: Scamp408] #203177
01/25/09 10:58 AM
01/25/09 10:58 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Here is mine after I re did the front end.
Re: wildwood brakes on a 69 dodge dart [Re: fasthawk6] #203178
01/25/09 02:16 PM
01/25/09 02:16 PM
Lil Demon Offline
Lil Demon  Offline
Part # AC-290. Besides, we would have measured everything and had them built to spec anyway. Your WWs are a huge improvement over factory.
Re: wildwood brakes on a 69 dodge dart [Re: Lil Demon] #203179
01/25/09 07:56 PM
01/25/09 07:56 PM
Cincinnati Oh
Cincinnati Oh
had a chance to do some measuring and came up with a 1/2" difference.also can you get longer studs that hold the axles in because when i add the rear bracket the studs are to short.
