Re: 88 360 block for build
[Re: gmachinedart1]
#2030769
03/14/16 05:47 AM
03/14/16 05:47 AM
RapidRobert
Justin I think you are OK but consider this a BTT till you get definite confirmation.
[Re: gmachinedart1]
#2030794
03/14/16 10:28 AM
03/14/16 10:28 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Only major difference is the lifter bosses are taller on the 88 block, you can still run any flat tappet cam you want, with appropriate pushrods as well.
[Re: gmachinedart1]
#2031062
03/14/16 05:32 PM
03/14/16 05:32 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
roller block and flat tappet cam with W2 heads you will want to mock it up and make sure the PR don't touch the top of the lifter bore. If you run the hydraulic roller you will need to check for clearance of the PR to the intake port very carefully, probably clearance the heads then do your porting. Either way you will probably be stuck with 5/16 PRs... not the end of the world unless you want big RPM.
