V10 valve train trouble #2030653
03/13/16 11:37 PM
03/13/16 11:37 PM
Missouri
hemi jimmy Offline OP
Missouri
Have a 1999 dually v10 with 111,000 miles. Had a sudden engine miss show up a few weeks ago. Poked around on the net and found a few posts about rocker arm bolts breaking. Pulled valve covers & sure enough, #8 intake rocker bolt broken & pushrod laying there. All rockers extremely worn as well. After much research I found that stock rockers and pivots aren't available. Decided to install crower rockers & new lifters. Found one pushrod had rubbed thin on head gasket. Mine measure 7.765" long but parts stores want to sell me 7.900" pushrods. Can get an oil through Chevy pushrod at length I need. Anybody been this deep in a v10 and found the same parts issues?
Re: V10 valve train trouble [Re: hemi jimmy] #2030773
03/14/16 07:44 AM
03/14/16 07:44 AM
Guitar Jones Offline
Just get whatever pushrod you need that is the correct length. I would be more concerned as to why the rockers are worn so bad.
Re: V10 valve train trouble [Re: Guitar Jones] #2031426
03/15/16 02:11 AM
03/15/16 02:11 AM
Missouri
Missouri
I know what you're saying about rocker arm wear but I'm installing roller rockers. Not because I want to but because I can't find stock rockers. In all the research I've done, there's no mention of stock replacement rocker arms available and no mention of a 7.765" pushrod length for the truck V10 engine. I guess I'm just curious if I've got a strange combination or has anyone been through this and found the same issues.
Re: V10 valve train trouble [Re: hemi jimmy] #2031469
03/15/16 05:47 AM
03/15/16 05:47 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Depending on how many you actually want there are 2 new stock rocker arms on ebay right now. Part Number: 05245335
http://www.ebay.com/itm/Genuine-Mopar-Pa...rJb&vxp=mtr
The pivots are available too.
http://www.ebay.com/sch/i.html?_odkw=dod...83&_sacat=0
What part of Missouri are you in?
PM me if you'd be interested in a mostly complete 99 V-10 engine.
I don't want anyone to see this as a for sale ad and take offense.
Re: V10 valve train trouble [Re: hemi jimmy] #2031508
03/15/16 10:17 AM
03/15/16 10:17 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Isn't the valvetrain going to be all the same as any junkyard magnum engine?
Re: V10 valve train trouble [Re: SNK-EYZ] #2031959
03/15/16 10:57 PM
03/15/16 10:57 PM
Missouri
Missouri
Yeah... I've seen the one & two rockers for sale on ebay but I would need 20. That's ok, I have roller rockers on the way. Thanks for looking though. I'm more baffled by the fact that when I look for pushrods I don't find listing for v10's at 7.765" long???
Re: V10 valve train trouble [Re: DaytonaTurbo] #2031968
03/15/16 11:10 PM
03/15/16 11:10 PM
Missouri
Missouri
I recently checked out a 5.2 magnum & the valve train was completely different than my v10. Rockers & pivots are smaller and pushrods are shorter. I had hoped they were the same but no luck. I have no idea what year it was. That might make a difference. I'm a die hard Mopar man but I sure wish they made stuff more interchangeable!
Re: V10 valve train trouble [Re: hemi jimmy] #2032638
03/16/16 08:28 PM
03/16/16 08:28 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
As far as I know The valve train is the same as the 5.9l. My buddy has a '99 and he had a pushrod go thru the pocket on the rocker arm. He was on the road and got a replacement from a dealer but NOS stuff is running out. If I had kept mine I would be scrounging for parts to keep on a shelf.
Re: V10 valve train trouble [Re: hemi jimmy] #2033592
03/18/16 03:18 AM
03/18/16 03:18 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
i just got me a 97 2500 v10 w 138000 it super smooth and runs great and i did a sct tune by flyanryan, i drive mine easy tho i hope nothing like sensors or hard parts go out it seems finding parts is scarce
Re: V10 valve train trouble [Re: Cheatham] #2033920
03/18/16 05:02 PM
03/18/16 05:02 PM
Missouri
Missouri
I drive mine fairly easy too but I also use it for towing trailers. Yes, parts are a little tough to find and when you find them they're expensive. One suggestion given to me to help these engines is to install the coolest thermostat you can buy. This helps cut down on heat related engine sludge which can lead to some of the same problems I'm having with mine.
Re: V10 valve train trouble [Re: hemi jimmy] #2047636
04/06/16 01:57 AM
04/06/16 01:57 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I would think running it too cool would build more sludge than running hot.~RT
