Spark plug wire routing #203049
01/24/09 03:24 PM
01/24/09 03:24 PM
Illinois
Mopar_Ray Offline OP
Illinois
Trying to straighten out some things that I previously kinda tossed in as I got them. It's a Challenger with a 440 & 1-7/8 Hooker super comps, MSD pro billet distributor and MSD 8.5 mm super conductor wires (the pre-made ones). All the wires are too long. But before I cut them and put new ends on I'd like to find some pictures of how others have done it.
Re: Spark plug wire routing [Re: Mopar_Ray] #203050
01/24/09 03:30 PM
01/24/09 03:30 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I don't know how much this helps, but it gives me another opportunity to show off my engine compartment when it was still clean.
Re: Spark plug wire routing [Re: BradH] #203051
01/24/09 03:40 PM
01/24/09 03:40 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: Spark plug wire routing [Re: Ari440] #203052
01/24/09 04:02 PM
01/24/09 04:02 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
These are mostly out of the box. Hope it helps.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Spark plug wire routing [Re: sunroofgtx] #203053
01/24/09 04:30 PM
01/24/09 04:30 PM
Illinois
Illinois
Thanks all!
I am trying to use the cap that came with the MSD to hold the wires down ? But you lose a couple of areas to rout the wires. I also have a kind of dumb ? How come everyones #1 wire is in a different position?
Re: Spark plug wire routing [Re: Mopar_Ray] #203054
01/24/09 04:43 PM
01/24/09 04:43 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
YOU CAN PUT NO.1 WHERE EVER YOU WANT I JUST LIKE MINE ON THE ds SO IT GOES STRAIT TO THE PLUG
Re: Spark plug wire routing [Re: Mopar_Ray] #203055
01/24/09 04:46 PM
01/24/09 04:46 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i like my wires organised & set up so they can't be accidentally put on the wrong plug.
Re: Spark plug wire routing [Re: Mopar_Ray] #203056
01/24/09 05:38 PM
01/24/09 05:38 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Thanks all!
how do you lose any areas? #1 wire can be anywhere you want it to. put it in the best location for your routing.
Re: Spark plug wire routing [Re: Quicktree] #203057
01/24/09 05:47 PM
01/24/09 05:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
here's a few pics of a SB routing.
Re: Spark plug wire routing [Re: Quicktree] #203058
01/24/09 05:47 PM
01/24/09 05:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
another
Re: Spark plug wire routing [Re: Quicktree] #203059
01/24/09 06:19 PM
01/24/09 06:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the wire for the rear cyl on each side along the top of the valve cover as it works nice with my 90 degree wires. Ron
Re: Spark plug wire routing [Re: 383man] #203060
01/24/09 06:22 PM
01/24/09 06:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Other side. Ron
Re: Spark plug wire routing [Re: 383man] #203061
01/24/09 09:14 PM
01/24/09 09:14 PM
Illinois
Illinois
Thanks all.
Gave me some inspiration. Have it pretty much figured out. I would share.. but after seeing clean motors, I would be embarrassed. Maybe some day?
Re: Spark plug wire routing [Re: Mopar_Ray] #203062
01/24/09 09:18 PM
01/24/09 09:18 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I made little stanchions out of excess 3/8" aluminum fuel line.
Ride eternal, shiny and chrome
Re: Spark plug wire routing [Re: Mopar_Ray] #203063
01/24/09 11:41 PM
01/24/09 11:41 PM
So. IL. USA
PLUM BAD Online happy
PLUM BAD  Online Happy
So. IL. USA
I have had good results running 5, 6, 7, and 8 under the intake and around the back of the heads, then under the headers. To me it looks cleaner and keeps them out of the way.
Re: Spark plug wire routing [Re: PLUM BAD] #203064
01/25/09 09:58 AM
01/25/09 09:58 AM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
From a few years ago. I copied another board member at the time.. It takes time to figure it out, but looks cool when ya get it done..
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Spark plug wire routing [Re: KatFysh] #203065
01/25/09 11:58 AM
01/25/09 11:58 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
This does look VERY nice! Thanks for "carrying the tradition" from the other member.
I understand that cylinders #5 & #7's wires should never be run next to each other at all due to the cylinders timing events and the possibility of induced spark from #5 seting off #7's charge WAAAAYYY before it should normally fire(with an air/fuel mixture beginning the compression stroke) causing potentially catostrophic damage.
Does anyone consider this in their routing?
Re: Spark plug wire routing [Re: jbc426] #203066
01/25/09 12:31 PM
01/25/09 12:31 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
I don't have the car anymore and can't do that with the Firecore 50's I have now. Those wires were Taylor Spiro Pro's 10.4mm. Not much worry with cross firing with those. I still have 6 of the 8 wires..
What have I now..
Re: Spark plug wire routing [Re: BradH] #203067
02/09/09 04:13 PM
02/09/09 04:13 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
This is for Lyle
Re: Spark plug wire routing [Re: Mopar_Ray] #203068
02/09/09 04:20 PM
02/09/09 04:20 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
