Looing for some part numbers for a 1976 B200 #2029828
03/12/16 04:17 PM
03/12/16 04:17 PM
Appleton WI 54911
Lukester Offline OP
Lukester  Offline OP
Appleton WI 54911
Looking for the part numbers for the rear (fixed) door glass seals on a 1976 dodge B200 cargo van. Looking for the seals that go around the glass... The van has 2 doors in the back with a fixed window in each.... Thanks
Re: Looing for some part numbers for a 1976 B200 [Re: Lukester] #2030146
03/13/16 10:03 AM
03/13/16 10:03 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I suspect your not going to find replacement seals by using Mopar part numbers. Even if you could find the numbers, do you really want to put in "new" rubber from 1976?
There are a lot of places where you can buy generic glass to metal seals. Softseal comes to mind, even JC Whitney has some. You will probably need to get a profile view of what your seals look like (or are suppose to look like), then go online to get a correct profile (or as close as you can get), and buy however many feet of that profile seal you will need to go around your windows. Once you get the new seals sized correctly, you use Superglue and glue the ends of the seals together and install the glass into your doors.
Gene
Re: Looing for some part numbers for a 1976 B200 [Re: poorboy] #2030236
03/13/16 02:04 PM
03/13/16 02:04 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Shows 1977 as different and 3731782 for 74-75-76 and they're on eBay now
Red
Re: Looing for some part numbers for a 1976 B200 [Re: Lukester] #2030506
03/13/16 09:18 PM
03/13/16 09:18 PM
Appleton WI 54911
Lukester Offline OP
Lukester  Offline OP
Appleton WI 54911
Awesome..... Exactly what I needed. Much appreciated... Luke
